Has anyone been able to create the ODBO connection between two Tm1 severs (x64) ?
I have two x64 Tm1 9.5.2 servers with CAM authentication. They are located on the same adminhost.
I need to create ODBO connection between them. The thing is IBM have a very poor section (Connecting
to an OLE DB for OLAP Datasource When Using CAM Authentication ) in the TurboIntegrator Guide.
Underlined bold text says us that we should use connection string instead of TI user interface. The question is what means 'connection string' here?If you are running a 64-bit version of the TM1 server, you must specify the CAM namespace ID through a
connection string, using the same format noted above. For example the following connection string specifies a CAM namespace ID named NTLM_NAMESPACE:
Provider=TM1OLAP.1;Location=localhost;Data Source=empty;UserID=tm1user;Password="abc123";
Provider String="CAMNamespace=NTLM_NAMESPACE";InitialCatalog=empty
You cannot use the TurboIntegrator user interface to specify the CAM namespace when running a 64-bit TM1 server; you must use a connection string.
Thank you in advance for sharing your experience!
