Matrix determinant
Elessar
OLAP Product: PA 2
Version: 2.0.9
Matrix determinant
Post by Elessar »
Hello all,
I have a 2-dim cube with equivalent dimensions (an NxN matrix) and need to calculate it's determinant. Did anybody do this using only rules, without processes?
rmackenzie
Re: Matrix determinant
Post by rmackenzie »
Elessar wrote:I have a 2-dim cube with equivalent dimensions (an NxN matrix) and need to calculate it's determinant.
If N was only going to be 2, or 3, then you could do something like this with the inclusion of a measures dimension:
SKIPCHECK;
['Measure':'Input'] = N: STET;
# 2x2 grid
['Row':'a', 'Column':'a', 'Measure':'Output'] = N:
  IF ( DB ( 'Calc Control', 'Grid Size', 'Number' ) = 2,
    ( ['Row':'a','Column':'a','Measure':'Input'] * ['Row':'b','Column':'b','Measure':'Input'] )
    ( ['Row':'a','Column':'b','Measure':'Input'] * ['Row':'b','Column':'a','Measure':'Input'] ),
    CONTINUE
# 3x3 grid
  IF ( DB ( 'Calc Control', 'Grid Size', 'Number' ) = 3,
    ( ['Row':'b','Column':'b','Measure':'Input'] * ['Row':'c','Column':'c','Measure':'Input'] )
    ( ['Row':'b','Column':'c','Measure':'Input'] * ['Row':'c','Column':'b','Measure':'Input'] ) )
    ( ['Row':'b','Column':'a','Measure':'Input'] * ['Row':'b','Column':'c','Measure':'Input'] )
    ( ['Row':'b','Column':'c','Measure':'Input'] * ['Row':'c','Column':'a','Measure':'Input'] ) )
    ( ['Row':'a','Column':'c','Measure':'Input']
    ( ['Row':'b','Column':'a','Measure':'Input'] * ['Row':'c','Column':'b','Measure':'Input'] )
    ( ['Row':'b','Column':'b','Measure':'Input'] * ['Row':'c','Column':'a','Measure':'Input'] ) ),
    CONTINUE
# no calcs where grid size is > 3 % non-a and non-a combos
['Measure':'Output'] = N: STET;
FEEDERS;
['Measure':'Input'] => ['a', 'a', 'Output'];
If you don't know N, then I'd prefer to use TI as it is likely you can write one TI to handle any N.
Why don't you know N?
Robin Mackenzie
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
Hi and thanks for reply
I'm going to do the Reciprocal Method of cost allocation from one Dep. to another: http://classes.bus.oregonstate.edu/Spri ... r%2012.htm
The most difficult there is to solve the system of linear equations.
N is not fixed: "Department" a dinamically updated dimension
rmackenzie
Right, I see - so the number of departments is going to be unknown.
There's a bit of VB here that solves an NxN matrix determinant problem in 39 lines of code. It looks possible to rewrite in TI, at a glance. So, why not leverage that and hook it to an Action Button and get your users to use that?
Function determinant(Matrix() As Single, Norder As Integer, deter As Single)
Dim k, k1, i, j As Integer
Dim save As Single
Dim check As Boolean
deter = 1
For k = 1 To Norder
 If Matrix(k, k) = 0 Then
  j = k
  Do
   check = True
   If Matrix(k, j) = 0 Then
    If j = Norder Then
     deter = 0
     Exit Function
    End If
    check = False
    j = j + 1
   End If
   If Matrix(k, j) <> 0 Then
    For i = k To Norder
     save = Matrix(i, j)
     Matrix(i, j) = Matrix(i, k)
     Matrix(i, k) = save
    Next i
    deter = -deter
   End If
  Loop While check = False
 End If
 deter = deter * Matrix(k, k)
 If k - Norder < 0 Then
  k1 = k + 1
  For i = k1 To Norder
   For j = k1 To Norder
    Matrix(i, j) = Matrix(i, j) - (Matrix(i, k) * Matrix(k, j) / Matrix(k, k))
   Next j
  Next i
 End If
Next k
End Function
Robin Mackenzie
