Hi everyone,
I need to run a TI process opening an approval hierarchy node (the ENTER workflow action).
Unfortunately this features:
- is documented in the IBM Knowledge Center (http://www-01.ibm.com/support/knowledge ... ml?lang=en)
- this action is present in the }tmp_workflow_action dimension of the cube }tmp_workflow_action_TI that stores this kind of information
BUT the TM1 Performance Modeler interface DON'T SHOW THIS ACTION TO SET-UP THE PROCESS (also don't show the action LEAVE)
Inserting manually the values in the }tmp_workflow_action_TI cube doesn't produce any effects.
Does any other experimenting this problem? Any suggestion?
My environment is TM1 10.2.2.1
Thankyou in advance and best regards.
Ottavio
TurboIntegrator process on a workflow action
pandinus
- Excel Version: 2013
Re: TurboIntegrator process on a workflow action
Please check the following page from IBM: http://www-01.ibm.com/support/docview.w ... wg1PI16592
While they state that you should upgrade to 10.2.2 FP1 I have to tell you that my installation of 10.2.2 FP2 is not showing the options either..
Maybe they will be back in 10.2.2 FP3, scheduled for release this month!
ottaviopf
- OLAP Product: TM1 - Planning Analytics Local
- Version: TM1 10.2.2.7 - PA 2.05
- Excel Version: 2007 - 2010 - 2013
Dear pandinus,
thank you for your prompt and effective reply.
I will wait for next FP3.
Best Regards
Ottavio
Best Regards
Ottavio
Willi
- Version: 9.5.2
it's a pretty old post but I also run in this problem. I have 10.2.2 with FP7 installed. Even than I don't have this option. Does anyone has something like a workaround?
Thx and best regards,
Willi
Willi
