Hi Team,
I have replicated one cube (C1) from one server (T1) to another server (T2) with all dimensions, i am able to see the data and control object as well on T2 server cube. But when i use the same cube as a data source in Framework Manger (10.1.1) not able to see dimensions. If i create another cube (C2) (on replicated server T2, using the same dimension) able to see same dimensions are coming in Framework manger. But I don't now what's the reason, why not for for this cube (C1) . Is it due to the same cube (C1) is already used in Framework Manger from T1 server and that's why this is not recognized it. Even created new connection everything in FM, no help
Is it issue with replication process or something else ?
