MDX , create subset by value in other cube
sk1080in
- Version: Planning Analytics
I have a value written in one of the lookup cubes (Example: W010215, W050115, W040115) and on the basis of first 3 characters want to create subset in another dimension which has values like W01, W02, W03....
So whatever the value is in lookup cube, should become the basis for subset in another dimension.
Can somebody guide me if this is possible.
rmackenzie
Re: MDX , create subset by value in other cube
TM1 supports the LEFT function - it may likely be un-documented and differ between versions etc.
Anyway, you can do something like this:
Note the concatenation of the wildcard character (*) at the end of the filter.
{TM1FILTERBYPATTERN(
{TM1SUBSETALL([Interesting W Things])},
LEFT(
[Control Cube].(
[Control Parameter Dimension].[Some Parameter],
[Control Measure Dimension].[String]
3
)}Robin Mackenzie
sk1080in
Thanks a lot, it is working fine, however giving all levels of elements starting with the 3 characters selected. Can it be restricted to 0 Level only ?
ardi
- Version: from TM1 9.4 to PA 2.0.9.6
You can embed the above statement with TM1FILTERBYLEVEL and that will give you only level zero elementssk1080in wrote:Thanks a lot, it is working fine, however giving all levels of elements starting with the 3 characters selected. Can it be restricted to 0 Level only ?
Ardian Alikaj
EvgenyT
- Version: PAL 2.0.8
You are right, it's not documented anywhere.TM1 supports the LEFT function - it may likely be un-documented and differ between versions etc.
BTW RIGHT function is supported too (not documented of course)
sk1080in
Thanks a lot everyone, it has worked for me. Last question...Can I pick something from between as well ? Like start from 4th Character and pick 2 Characters ?
EvgenyT
To my knowledge (and from testing) MID function is not supported in TM1 MDX.
rmackenzie
But you can achieve the output of a MID if you have LEFT, RIGHT and LEN. E.g. this will work:EvgenyT wrote:To my knowledge (and from testing) MID function is not supported in TM1 MDX.
{TM1FILTERBYLEVEL(
0
LEFT(
RIGHT(
[Control Cube].(
LEN(
[Control Cube].(
) - 4 + 1
), 2
)}Robin Mackenzie
sk1080in
Brilliant Solution, Thanks for that. You are a Star.
