We are using TM1 10.2.2 Applications (as production server)in one server.
Through Bridge server (TM1 Client 10.2.2)the users will access those TM1 Application.
Whenever any new users logged into the bridge server the user needs to enter the IP of the production server Admin Host.
Is there any way to make this server IP as default Admin Host. so that the users no needs to do manually of changing the Admin host.
Could you please share you suggestion .
Thanks !
Palani
Moved to the correct forum - admin team
TM1 Admin host Change
- paulsimon
- Version: PA 2.0.5
Re: TM1 Admin host Change
Hi Palani
By TM1 Applications I guess you mean you are using TM1 Web. Personally I have never used TM1 Applications as I have never encountered a client where the default workflow meets their needs. However, the core is TM1 Web. If you look at the TM1 Web Guide in the section on Cognos TM1 Web Configuration Parameters, you will find a parameter called Admin Host Name. If you set that to the required value, then the users won't get promoted for this. You can also set the name of the TM1 Server.
