No error messages shown
marine
Version: 10.1.1
Post by marine »
I'm trying to execute a TI process in PM, but every time I get a message: "Import failed" with no further details. When trying to change something in the process, I get only "No message text found." I wonder what could be the problem? This is a Cloud based TM1 and I all I could find are the following errors from the server log (from this morning):
1488 [4] ERROR 2015-02-25 08:22:25.806 TM1.Mdx.Interface Syntax error at or near: '[}CubeCaptions]', character position 90
1488 [4] ERROR 2015-02-25 08:22:25.884 TM1.Mdx.Interface Syntax error at or near: '[}CubeCaptions]', character position 90
1488 [4] ERROR 2015-02-25 08:22:25.884 TM1.Mdx.Interface Syntax error at or near: '[}DimensionCaptions]', character position 90
1488 [4] ERROR 2015-02-25 08:22:25.884 TM1.Mdx.Interface Syntax error at or near: '[}ElementCaptions]', character position 90
1488 [4] ERROR 2015-02-25 08:22:25.899 TM1.Mdx.Interface Syntax error at or near: '[}CubeCaptions]', character position 88
3924 [13] ERROR 2015-02-25 08:25:29.409 TM1.Server Could not attach thread to Java Virtual Machine, JVM is NULL
3924 [13] ERROR 2015-02-25 08:25:29.409 TM1.Process Process "}_intDPD_CallFeederGen_{3a7ebcb6-e997-4175-a870-7be82479271f}": : Execution was aborted. Error file: <TM1ProcessError_20150225082529_}_intDPD_CallFeederGen_{3a7ebcb6-e997-4175-a870-7be82479271f}.log> : Errors occurred during execution of process "com.cognos.pmta.feedergen.standalone.GenerateFeedersAutoRulesOnly". Check error log file for that process for more details
I tried restarting the server once but the problem continues.
Re: No error messages shown
Have a look inside the error log file created:
should be in your Logs folder as specified in the TMS1.CFG file. This may give you some more insight.
BR, George.
marine
Version: 10.1.1
Post by marine »
gtonkin wrote:Have a look inside the error log file created:
Hi, thanks for your reply! The file you referred to includes only:
Error: Prolog procedure line (3): Errors occurred during execution of process "com.cognos.pmta.feedergen.standalone.GenerateFeedersAutoRulesOnly". Check error log file for that process for more details
marine wrote: Hi, thanks for your reply! The file you referred to includes only:
Then there will be another log file in the same folder around the same time with the name of that process in it. Check that error log file for more details.
marine
Version: 10.1.1
Post by marine »
Ok, thanks! For some reason I cannot find a file like this, but I'll continue trying to solve the problem.
CognosConnect
OLAP Product: TM1, CX, MSAS, C8 BI
Version: TM1 9.5.2 CX 9.5.0
Post by CognosConnect »
Have you solved your problem?
I have a very similar problem when deploying application in Performance Modeller
star4ulove
Version: 10-2-2
Post by star4ulove »
Any update on this , I am having same issue I am using 10.2.2 FP3 ,
But performance modeler not able to deploy the Approval hirarechy Application.
star4ulove
Version: 10-2-2
I am facing same issue, which you had faced in Jun-15, related performance
modeler ,
I am trying to deploy an Approval hirarechy application , but "JVM is null
, & could not connect to Java thread" error.
Please help me in resolving issue
I am using 10.2.2 FP3, OS windoes 2012 server R2, I think issue is that Tm1
process not able to connect JVM,
I have set system veriable JAVA_HOME value = D:\Program Files\ibm\cognos\tm1_64\bin64\jre\7.0
