Execute process "as admin"?
kastellu
Version: 9.5.2
Excel Version: 2008
Post by kastellu »
Please help us with this issue.
I would like to know if there is any possibility to execute process in TM1 as a different user. For example "execute as admin".
We have developed a solution that requires execution of tp_workflow processes. When we execute this processes using "admin" user everything works just fine, but execution of processes using non-admin user is problematic.
Non-admin user was set as part of a security group that has "WRITE" privileges on all TM1 objects ( cubes, dimensions , processes ), but this didn't help.
Could you please help me?
Br
qml
Excel Version: 2007 - 2016
Re: Execute process "as admin"?
Post by qml »
kastellu wrote:I would like to know if there is any possibility to execute process in TM1 as a different user.
Yes, you can use the tm1runti command line tool to run processes as another user. However, that's not necessary for what you are trying to do. Broadly speaking, TI does not run with the access rights of the person running it. You should find this thread useful; it describes this subject in detail.
Kamil Arendt
Gabor
Version: [2.x ...] 11.x / PAL 2.1.13
Excel Version: Excel 2016-2021-365
Post by Gabor »
Did you check "Security Access" after a right mouse click on the process (in Perspectives for example)?
This should make any user really acting as full admin while running the process, otherwise non admin users or chores are still limited on certain actions.
