Does anyone know if its possible to reject multiple nodes within the Workflow Hierarchy (TM1 Application)? There are several nodes (75) under one parent and rather than rejecting each one individually we would like to reject all at once.
We are using Cognos Express 10.2
Appreciate your responses
Lance
TM1 Applications - Rejecting Multiple Nodes
- Version: 10.2.2 Fix Pack 4
- Excel Version: 2013
Re: TM1 Applications - Rejecting Multiple Nodes
Create a process which loops over your elements and calls the }tp_workflow_reject_node process for each node you need to reject.
