10.2.2 RunTI.exe with SSO
holger_b
Post by holger_b »
Did anybody ever manage to implement the use of TM1RunTI.exe in an 10.2.2 SSO environment, and do you feel ready to give some advice? So far, we did not manage to make the process log on.
Thank you
Holger
dan.kelleher
Version: 9.4
Excel Version: 11
Re: 10.2.2 RunTI.exe with SSO
Post by dan.kelleher »
HI,
We have it working in 10.2 FP2:
"D:\Program Files\ibm\cognos\TM1_10_2_64_DEV\bin64\tm1runti" -i "D:\xxx\tiprocess.config" -connect instance_label -process cube_clear_view  psCube="xxx" psMonth="2014_01"
tiprocess.config contains the following information:
[TM1RunTi]
[Connect - instance_label]
adminhost=
server=servername
user=adminCAMuser
pwd=
passwordfile=D:\xxx\adminCAMuser_pwd.txt
passwordkeyfile=D:\xxx\adminCAMuser_key.dat
adminsvrsslcertid=tm1adminserver
adminsvrsslcertrevlist=
exportadminsvrsslcert=F
adminsvrsslexportkeyid=F
camnamespace=someCAMnamespace
The password has been encrypted using TM1Crypt (google it if you haven't used it before).
Dan
holger_b
Post by holger_b »
Thanks a lot, Dan. I hope the day comes soon when I'll have time to proceed with this, I will post my learnings.
Holger
holger_b
Post by holger_b »
It works like you said, Dan. Basically, you just need to add the CAMNamespace parameter to make it work, and use the windows password instead of the TM1 password.
See also this document: http://www-01.ibm.com/support/docview.w ... wg21656832
