Saving the rule file and recalculation of feeders
mvaspal
OLAP Product: tm1
Version: 10 2 2 - 2.0.5
Post by mvaspal »
I am wondering this is a new feature in 10.2.x, I saw it in 10.2.2 now, or did I miss it in earlier versions?
I changed a rule and saved it but did not change the feeder section. The rule was saved in 1 sec, no feeder recalc was kicked off. Then I amended the feeder section, saved the rule, it took much longer because it recalculated the feeders.
If it is a new feature it is really useful because if you need to amend a rule in a cube with heavy feeders but you do not need to change the feeders then it takes a second to save the rule, enabling such changes even during peak usage periods.
Matyas
Re: Saving the rule file and recalculation of feeders
Yes. This is new in 10.2 and (generally) very useful. If feeder definition is not changed then rule save is limited to rule recompilation and feeder generation only if feeder section is changed.
mvaspal
OLAP Product: tm1
Post by mvaspal »
Thanks for quick response, I find it also great
Nice, they kept that quiet, a genuine step forwards!
TrevorGoss
Version: 10.2.1.1
Excel Version: 14.0.6129.5000
Post by TrevorGoss »
This does indeed sound useful, is there documentation on this new feature?
Post by David Usherwood »
We've dug into this a bit further - see here. Key takeaway is that the old 'Spacebar save' no longer fires feeders - you need to use CubeProcessFeeders instead. On balance, an improvement I'd say.
TrevorGoss
Version: 10.2.1.1
Thanks for that Dave.
In performance Modeler, inside the properties tab of a TM1 service, there is an option called "Generate feeders automatically", this gives you a drop down list of 3 options: "No","Only automatically generated rules" and "All rules".
Are you aware of this and do you know if it makes a difference to the kicking of feeders. If I select "All rules", can choosing this option act as a replacement for using the CubeProcessFeeders function?
Thanks.
Trevor.
mvaspal
OLAP Product: tm1
Post by mvaspal »
I never used it but I would think the All Rules option generates feeder statements for your rule lines (including those manual rules that you wrote), and it is not for re-firing the existing feeders.
That's likely only going to be applicable to PM. How do I know? I don't for sure but common sense would tell me that for the TM1 service to know what to do during a rule save either the service would have a setting to tell it what to do or the client interface would. In this situation I know there is no setting in the TM1S.cfg file for this so the service isn't going to know automatically what to do so PM is going to be the one to tell it what to do. If you are doing all your development in PM then your OK. If you are doing a mixture then this isn't go to be a complete replacement for CubeProcessFeeders.
TrevorGoss
Version: 10.2.1.1
Mvaspal and Tom,
thanks for both of your resposnes.
We do not develop in Performance Modeler, partly because of legacy, partly because it gets on our nerves.
You are most likely correct Tom, its not as if the CubeProcessFeeders function call is a real difficulty, especially if you run it as a start up chore, or a chore during the middle of the night.
Thanks.
