TM1 connecting to a Web Service
recoliveira
Post by recoliveira »
Hi all!
I need to read some information that is available through a web service. What do I do in TM1 to access this information and save in a cube?
Thanks a lot!
Renata
blackhawk
Re: TM1 connecting to a Web Service
Post by blackhawk »
Renata,
If you have 10.2, you can use the REST API
https://www.ibm.com/developerworks/comm ... I%2010.2.2
EDIT: Oh...oops...I read that the wrong direction. :(
Are you trying to get data into TM1 from a web service via a TI script?
recoliveira
Hi blackhawk!
Yes, via TI script. Is it possible? If not, should I use only the REST API?
Thank you!
Harvey
Version: TM1 8.3 onwards
Excel Version: 2003 onwards
Post by Harvey »
TM1 does not have any built in functionality to connect to external web services.
If you would like to import data from a web source, you would need to write a custom executable or script to do the work.
Many approaches are possible. For instance, the program/script might poll the web service periodically and write the data to the file system. You could pick this up with a scheduled chore that imports the local file into a TM1 cube. Alternatively, you might opt to write executable application that gets the data, then uses the TM1 API to fire off a TI process to import it.
How you approach it really depends on the scenario, connectivity and nature of the data.
Harvey wrote:..., then uses the TM1 API to fire off a TI process to import it.
Or TM1runti.exe can be used.
blackhawk
Post by blackhawk »
Actually, the way I would consider doing it is create a Java extension to pull the data from a web service and then write it to a file. The java extensioni could be called from the TI script in the prolog section. Then, the TI processes like normal using this new file.
vWSUrl = 'http://myserver/getdata';
vTempFile = 'filename.tmp';
retVal = ExecuteJavaN( 'com.sample.GetWSData',vWSUrl, vTempFile );
If( retVal > 0 )
    ProcessQuit;
EndIf;
DatasourceNameForServer = vTempFile
You can make the GetWSData dumb, in that all it does is take the data from the web service and write it to a CSV or tab delimited file. Then leave it up to the TI process to understand what columns it should load or not load.
Hope that helps.
tianoklein
Post by tianoklein »
Hi blackhawk,
Did you try this ???
http://tm1server:9510/pmpsvc/services
http://www.tm1forum.com/viewtopic.php?f=3&t=11028
OR
Did you try to create a TI - TM1 SDK JavaExtensions??
http://www.tm1forum.com/viewtopic.php?p=51180
Please let me know if you have succeeded, because I have the same problem and could not find a solution. :roll:
