When I do "reorder dimensions" last dimension contains string element, generates an error "Dimension Re-Order Failed". You do "reorder dimensions" last Dimension?
Thanks.
reorder dimensions string elements
Re: reorder dimensions string elements
In a word, No.bogdan wrote:Hi,
Thanks.
IBM wrote: You cannot change the order of a string dimension that exists as the final dimension in a cube definition.
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
I do however recollect being able to add a string element to the last dimension after doing the reorder - and everything worked fine as far as I recall.
Not that I'm advocating it mind. It's just that sometimes documentation fails to tell the full story. It might be worth experimenting.
