I am currently having some problem with TM1 web-
after the installation of TM1 web- when i try to access site http://a4md04129/TM1Web/TM1Weblogin.aspx
I am getting following error- please advise- (Note: when i first time installed earlier it was working -second time i uninstalled and re-installed it is not working) and getting the following msg.
IBM Confidential
OCO Source Materials
BI and PM: tm1web
(C) Copyright IBM Corp. 2007, 2009
The source code for this program is not published or otherwise
divested of its trade secrets, irrespective of what has been
deposited with the U.S. Copyright Office.
<%@ Page language="c#" Codebehind="TM1WebLogin.aspx.cs" AutoEventWireup="false" Inherits="Applix.TM1.Web.Page.TM1WebLogin" %>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN" >
<HTML>
<HEAD>
<title><%=sTitle%></title>
<script language="javascript" src="scripts/tm1web/common.js"></script>
<script language="javascript" src="scripts/tm1web/login.js"></script>
<LINK href="css/login.css" type="text/css" rel="stylesheet">
<LINK href="<%=UserStyle%>" type="text/css" rel="stylesheet">
<link rel="icon" href="images/favicon.ico" type="image/x-icon">
<link rel="shortcut icon" href="images/favicon.ico" type="image/x-icon">
</HEAD>
<body id="loginBody" background="images/login/swoosh.png" onLoad="init('<%=errMsg%>');">
<div id="loginBoxWithShadow" cellpadding="0" cellspacing="0" border="0">
<div id="loginBox">
<div id="loginBoxInner">
<form method="post" name="Form1" id="Form1" runat="server">
<div id="loginTitle"><%=lblLogin%></div>
<div id="loginInput">
<%=lblDescription%><br /><br />
TM1 web problem
- Version: 9.1.4 FP1
Re: TM1 web problem
for me it looks like if iis could not interpret aspx
check if you have .net 2 enabled in iis
- OLAP Product: cognos
- Version: tm1 9.5
Re: TM1 web problem
I removed and IIS installation and re-installed- still the same problem and checked .net services are eanabled.
please advise further.
regards,
ravi
regards,
ravi
Re: TM1 web problem
upload screenshots of your iis configuration
- Version: tm1 9.5
Re: TM1 web problem
Yes-done- Working fine now-appreciate your help-thank U
- Version: tm1 9.5
Re: TM1 web problem-again
got following error whlie accssing tm1 web-log-in.
Server Error in '/' Application.
The resource cannot be found.
Description: HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable. Please review the following URL and make sure that it is spelled correctly.
Requested URL: /TM1Web/TM1Weblogin.aspx
Version Information: Microsoft .NET Framework Version:2.0.50727.1873; ASP.NET Version:2.0.50727.1433
- Version: 10.1
Re: TM1 web problem
Hi are u here? Did you remember that how to solve the problem??ravi wrote:Yes-done- Working fine now-appreciate your help-thank U
