TM1 web problem
ravi
OLAP Product: cognos
Version: tm1 9.5
TM1 web problem
Post by ravi »
I am currently having some problem with TM1 web-
after the installation of TM1 web- when i try to access site http://a4md04129/TM1Web/TM1Weblogin.aspx
I am getting following error- please advise- (Note: when i first time installed earlier it was working -second time i uninstalled and re-installed it is not working) and getting the following msg.
IBM Confidential
OCO Source Materials
BI and PM: tm1web
(C) Copyright IBM Corp. 2007, 2009
The source code for this program is not published or otherwise
divested of its trade secrets, irrespective of what has been
deposited with the U.S. Copyright Office.
<%@ Page language="c#" Codebehind="TM1WebLogin.aspx.cs" AutoEventWireup="false" Inherits="Applix.TM1.Web.Page.TM1WebLogin" %>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN" >
<HTML>
<HEAD>
<title><%=sTitle%></title>
<script language="javascript" src="scripts/tm1web/common.js"></script>
<script language="javascript" src="scripts/tm1web/login.js"></script>
<LINK href="css/login.css" type="text/css" rel="stylesheet">
<LINK href="<%=UserStyle%>" type="text/css" rel="stylesheet">
<link rel="icon" href="images/favicon.ico" type="image/x-icon">
<link rel="shortcut icon" href="images/favicon.ico" type="image/x-icon">
</HEAD>
<body id="loginBody" background="images/login/swoosh.png" onLoad="init('<%=errMsg%>');">
<div id="loginBoxWithShadow" cellpadding="0" cellspacing="0" border="0">
<div id="loginBox">
<div id="loginBoxInner">
<form method="post" name="Form1" id="Form1" runat="server">
<div id="loginTitle"><%=lblLogin%></div>
<div id="loginInput">
<%=lblDescription%><br /><br />
Martin Erlmoser
OLAP Product: TM1, Cognos Express,..
Version: 9.1.4 FP1
Re: TM1 web problem
Post by Martin Erlmoser »
for me it looks like if iis could not interpret aspx
check if you have .net 2 enabled in iis
ravi
Version: tm1 9.5
Re: TM1 web problem
Post by ravi »
I removed and IIS installation and re-installed- still the same problem and checked .net services are eanabled.
please advise further.
regards,
ravi
Martin Erlmoser
Version: 9.1.4 FP1
Re: TM1 web problem
upload screenshots of your iis configuration
ravi
Version: tm1 9.5
Re: TM1 web problem
Post by ravi »
Yes-done- Working fine now-appreciate your help-thank U
ravi
Version: tm1 9.5
Re: TM1 web problem-again
Post by ravi »
got following error whlie accssing tm1 web-log-in.
Server Error in '/' Application.
The resource cannot be found.
Description: HTTP 404. The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable. Please review the following URL and make sure that it is spelled correctly.
Requested URL: /TM1Web/TM1Weblogin.aspx
Version Information: Microsoft .NET Framework Version:2.0.50727.1873; ASP.NET Version:2.0.50727.1433
Aruis.yu
Re: TM1 web problem
Post by Aruis.yu »
ravi wrote:Yes-done- Working fine now-appreciate your help-thank U
Hi are u here? Did you remember that how to solve the problem??
