I use TM1 9.5.2.
I write a process wich should copy some data from one cube to another. Done a couple of times. In the Prolog I just define Subsets and a view for the Destination-Cube, Zero it out and destroy View and Subsets.
After that I define Subsets and a View for the Source-Cube and assign it to "DatasourceCubeView". After that I want to process my data and than clean up in the Epilog with destroying the View and the Subsets.
That works without an Error and the View is build correctly. If I do not destroy the View and Subsets I see it is defined after the TI as I expected. Zerosupression is on but there are values. But neither MEtadata nor Data is entered.
Does anyone has an idea where I can look at?
TI Process Metadata and Data Tab are not processed
mvaspal
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
Re: TI Process Metadata and Data Tab are not processed
do you have rule calculated values in the source view? if yes, are they fed?
Considering Willi says he looked at the view in cube viewer with zero supression on it is probably much more likely that the reason for nothing happening in the data tab is that the view processing is skipping calcs and one of the dimensions in the view has been assigned a subset that has only C elements which is a pretty common mistake.mvaspal wrote:Hi
Willi
- Version: 9.5.2
Here is the complete Prolog: (the first section for destroying Source-View and Subsets are because I don't delete them in the Epilog during test)
The Values in the Source are not Calculated.
vCubSrc = 'Planung_Basis';
vCubDst = 'Mathematische_Jahresplanung';
vDimSrc1 = 'Szenario';
vDimSrc2 = 'Monat';
vDimSrc3 = 'Jahr';
vDimSrc4 = 'Produkt';
vDimSrc5 = 'Kennzahl';
vDimDst1 = 'Szenario_MPL';
vDimDst2 = 'Jahr';
vDimDst3 = 'Produkt_MPL';
vDimDst4 = 'Vertrieb_MPL';
vDimDst5 = 'Kennzahl';
vSub = '}load_Cube_Mathematische_Jahresplanung_Uebertrag_Plan_Daten';
vView = '}load_Cube_Mathematische_Jahresplanung_Uebertrag_Plan_Daten';
if (ViewExists(vCubSrc, vView) = 1, ViewDestroy(vCubSrc, vView), 0);
if (SubsetExists (vDimSrc1, vSub)=1, SubsetDestroy(vDimSrc1, vSub), 0);
if (SubsetExists (vDimSrc2, vSub)=1, SubsetDestroy(vDimSrc2, vSub), 0);
if (SubsetExists (vDimSrc3, vSub)=1, SubsetDestroy(vDimSrc3, vSub), 0);
if (SubsetExists (vDimSrc4, vSub)=1, SubsetDestroy(vDimSrc4, vSub), 0);
if (SubsetExists (vDimSrc5, vSub)=1, SubsetDestroy(vDimSrc5, vSub), 0);
### Destination-Part clearen ###
if (ViewExists(vCubDst, vView) = 1, ViewDestroy(vCubDst, vView), 0);
if (SubsetExists (vDimDst1, vSub)=1, SubsetDestroy(vDimDst1, vSub), 0);
if (SubsetExists (vDimDst2, vSub)=1, SubsetDestroy(vDimDst2, vSub), 0);
if (SubsetExists (vDimDst3, vSub)=1, SubsetDestroy(vDimDst3, vSub), 0);
if (SubsetExists (vDimDst4, vSub)=1, SubsetDestroy(vDimDst4, vSub), 0);
if (SubsetExists (vDimDst5, vSub)=1, SubsetDestroy(vDimDst5, vSub), 0);
SubsetCreate (vDimDst1, vSub);
SubsetElementInsert(vDimDst1,vSub,'Plan Basis',1);
SubsetCreate (vDimDst2, vSub);
SubsetElementInsert(vDimDst2,vSub,pJahr,1);
SubsetCreatebyMDX(vSub,'{TM1FILTERBYLEVEL( {TM1SUBSETALL( ['|vDimDst3|'] )}, 0)}');
SubsetCreatebyMDX(vSub,'{TM1FILTERBYLEVEL( {TM1SUBSETALL( ['|vDimDst4|'] )}, 0)}');
SubsetCreate (vDimDst5, vSub);
SubsetElementInsert(vDimDst5,vSub,'Absatz',1);
SubsetElementInsert(vDimDst5,vSub,'Umsatz',1);
ViewCreate (vCubDst, vView);
ViewSubsetAssign(vCubDst, vView, vDimDst1, vSub);
ViewSubsetAssign(vCubDst, vView, vDimDst2, vSub);
ViewSubsetAssign(vCubDst, vView, vDimDst3, vSub);
ViewSubsetAssign(vCubDst, vView, vDimDst4, vSub);
ViewSubsetAssign(vCubDst, vView, vDimDst5, vSub);
ViewZeroOut(vCubDst, vView);
### Source-View definieren ###
SubsetCreate (vDimSrc1, vSub);
SubsetElementInsert(vDimSrc1,vSub,'Plan',1);
SubsetCreate (vDimSrc2, vSub);
SubsetElementInsert(vDimSrc2,vSub,'Alle Monate',1);
SubsetCreate (vDimSrc3, vSub);
SubsetElementInsert(vDimSrc3,vSub,pJahr,1);
SubsetCreatebyMDX (vSub, '{FILTER( {TM1SUBSETALL( ['|vDimSrc4|'] )}, ['|vDimSrc4|'].[TransferToRV] <> "")}');
SubsetCreate (vDimSrc5, vSub);
SubsetElementInsert(vDimSrc5,vSub,'Absatz',1);
SubsetElementInsert(vDimSrc5,vSub,'Umsatz',1);
ViewCreate (vCubSrc, vView);
ViewSubsetAssign(vCubSrc, vView, vDimSrc1, vSub);
ViewSubsetAssign(vCubSrc, vView, vDimSrc2, vSub);
ViewSubsetAssign(vCubSrc, vView, vDimSrc3, vSub);
ViewSubsetAssign(vCubSrc, vView, vDimSrc4, vSub);
ViewSubsetAssign(vCubSrc, vView, vDimSrc5, vSub);
## Nullwert-Unterdrückung im Source-View ##
ViewExtractSkipZeroesSet (vCubSrc, vView, 1);
## Unterdrückung Rule-berechneter Werte im Source-View ##
ViewExtractSkipRuleValuesSet(vCubSrc, vView, 0);
DatasourceCubeView = vView;
AsciiOutput('D:\Temp\debug.log1',DatasourceCubeView);
AsciiOutput('D:\Temp\debug.log1',vSub|' in '|vDimSrc1|' hat '|NumberToString(SubsetGetSize(vDimSrc1,vSub))|' Elemente');
AsciiOutput('D:\Temp\debug.log1',vSub|' in '|vDimSrc2|' hat '|NumberToString(SubsetGetSize(vDimSrc2,vSub))|' Elemente');
AsciiOutput('D:\Temp\debug.log1',vSub|' in '|vDimSrc3|' hat '|NumberToString(SubsetGetSize(vDimSrc3,vSub))|' Elemente');
AsciiOutput('D:\Temp\debug.log1',vSub|' in '|vDimSrc4|' hat '|NumberToString(SubsetGetSize(vDimSrc4,vSub))|' Elemente');
AsciiOutput('D:\Temp\debug.log1',vSub|' in '|vDimSrc5|' hat '|NumberToString(SubsetGetSize(vDimSrc5,vSub))|' Elemente');
vCount = 0;
Willi
- Version: 9.5.2
That is true.lotsaram wrote:Considering Willi says he looked at the view in cube viewer with zero supression on it is probably much more likely that the reason for nothing happening in the data tab is that the view processing is skipping calcs and one of the dimensions in the view has been assigned a subset that has only C elements which is a pretty common mistake.mvaspal wrote:Hi
If you want it to still pick it up then just add:Willi wrote:That is true.lotsaram wrote:Considering Willi says he looked at the view in cube viewer with zero supression on it is probably much more likely that the reason for nothing happening in the data tab is that the view processing is skipping calcs and one of the dimensions in the view has been assigned a subset that has only C elements which is a pretty common mistake.mvaspal wrote:Hi
This is a C-Element. That's not possible?Code: Select all
SubsetCreate (vDimSrc2, vSub); SubsetElementInsert(vDimSrc2,vSub,'Alle Monate',1);
ViewExtractSkipCalcsSet ( CubeName, ViewName, 0 );Declan Rodger
Willi
- Version: 9.5.2
Thx, that did the trick!
