Create an import TI manually
- Excel Version: 13
I've been searching for a topic regarding this but since I haven't been successful I decided to ask for some help here.
I have some TI processes running but I need to change them because of changes on the password access to the enviroments that I'm using as source.
I've created a cube to maintain the user and password for each dimension (I will apply security after), and I'm thinking on doing the odbc in the prolog:
DatasourceUsername=CellGetS(user in admin cube);
DatasourcePassword=CellGetS(password in admin cube);
ODBCOpen('ODBC Source',DatasourceUsername,DatasourcePassword);
DatasourceQuery = Expand ( 'Select * .......... from ........');
ODBCOutput('ODBC Source',DatasourceQuery );
My doubts are :
- How to map the variables (as in a TI using the datasource wizard;
- How to replicate the behavior of metadata and/or data that read through all records of the data source to either update dimensions or import data to a cube.
Can any one help me on this is (even by sending a helpful url or other post that maybe I haven't find it) ? thanks
My doubts are :
- jim wood
- Version: PA 2.0.7
Re: Create an import TI manually
I'm really not sure what you're trying to do? If you are looking to override the source query you're going about it in completly the wrong way. You need to use data override. Thne your variables have to match the original variables delivered by the original query. If you search data source override you'll fin plenty of topics on it like:
http://www.tm1forum.com/viewtopic.php?f=3&t=6020
This covers using a view as the data source but you'll get the idea,
Shop at Amazon
Shop at Amazon
- Excel Version: 13
Thanks Jim,
My situation is that I need to use some Oracle tables as sources in diferent processes (some to load dimensions, other do load data to cubes).
Because of security reasons I will have a cube to put the user and password for the odbc that only the admin group will have access.
I'm thinking on creating the datasource by code but when doing this I only have access to the epilog and prolog tab. My doubt is how to make the process run to all the records of the query in the data source and do the actions I want (either as metadata tab or data tab depending on the process).
Kind Regards,
Jorge
Kind Regards,
Jorge
TI isn't really sophisticated enough to re-map variables at runtime in a wizardy sort of way - for example, if your 'template' TI has 4 variables but you switch the DataSourceQuery to a table with 8 columns then there's little you can do to make the process recognise the extra 4 variables. Your option is to make the 'template' TI have the maximum number of variables you expect to find from the record-set of a query but then you may well have to write a lot of god-awful IF-based logic to decide how to map you dummy variable to a real field.jviegas@bi4all.pt wrote: My doubts are :
It sounds like you are attempting to create the 'template' TI to work for any dimension building/ updating process. To get this sort of pattern up and running you need to work with the database you are using as a source and create a 'template' view on any table used as an input for the dimension update process. For example, if all dimensions just need 4 columns which are DimName, ParentName, ChildName, Weight then you can set-up a single TI to have 4 variables and then make sure that the SQL you pass to DataSourceQuery only will ever have these 4 columns in it's record set.jviegas@bi4all.pt wrote: My doubts are :...
Your code then becomes a simple matter of:
# sql using pDimName as parameter
SELECT DimName, ParentName, ChildName, Weight FROM '?SOURCE_TABLE?'
WHERE DimName = '?pDimName?'
# Metadata
DimensionElementInsert ( pDimName, '', ParentName, 'n' );
DimensionElementInsert ( pDimName, '', ChildName, 'n' );
DimensionElementInsert ( pDimName, ParentName, ChildName, Weight );
Robin Mackenzie
- Excel Version: 13
Hi rmackenzie,
My problem is that by defining the odbc by code I don't have access to the metadata and data tab.
Picking from your example
Prolog
Then where and how should I use
Metadata and Data is disable because I don't have the datasource with any (it was coded in prolog) and I only have epilog available.
I honestly never had to do this like that but in this case I have too.
Jorge
Prolog
DatasourceQuery = Expand (' sql using pDimName as parameter
SELECT DimName, ParentName, ChildName, Weight FROM SOURCE_TABLE
Jorge
Just define one TI and set the username, password and query to something that gives you 4 variables but using parameters e.g.:
At runtime, you can update the user/ password variables and the parameters:
Because you already set-up this TI with an ODBC data source, the Metadata and Data tabs are available for you to put code into.
# parameters
SOURCE_TABLE = 'YOUR_SOURCE_TABLE';
pDimName = 'YOUR_DIMENSION_TABLE';
Robin Mackenzie
- Excel Version: 13
Eheheh wouldn't imagine that to be the way. Going to try it and give a feedback (hopefully positive
Thanks for the explanation and time
No problem - good luck. The trick is to keep the SQL queries in a standard format for the way you retrieve the columns.jviegas@bi4all.pt wrote:Eheheh wouldn't imagine that to be the way. Going to try it and give a feedback (hopefully positive).
Robin Mackenzie
- Excel Version: 13
rmackenzie,
Worked perfectly.
Because I have the sql statement with the columns and I'm needing this because I'm building an admin cube with the user and password for each environment (dev, qa, prod) I don't have the issues with the columns.
So I've tested in a ti that is working and changed the prolog with :
(ADM_ODBC is the cube with the connections, user and passwords).
Run the TI process and everything worked with the variables created and metadata and data that were already build.
Thanks, as I said I wouldn't think this to be done like this
Worked perfectly.
DatasourceC=CellGetS('ADM_ODBC', 'Connection','PROD');
DatasourceUsername=CellGetS('ADM_ODBC', 'UsrLogon','PROD');
DatasourcePassword=CellGetS('ADM_ODBC', 'UsrPassword','PROD');
ODBCOpen(DatasourceC,DatasourceUsername,DatasourcePassword);
DatasourceQuery = Expand ('SELECT a,b,c from table;');
ODBCOutput(DatasourceC,DatasourceQuery );
Why are you doing an ODBCOpen/Output/Close if all you are trying to do is set the datasource query? You have already done that by specifying the DataSourceQuery, I would also consider adding DataSourceNameForServer just for completeness sake.jviegas@bi4all.pt wrote:rmackenzie,
Worked perfectly.
(ADM_ODBC is the cube with the connections, user and passwords).Code: Select all
DatasourceC=CellGetS('ADM_ODBC', 'Connection','PROD'); DatasourceUsername=CellGetS('ADM_ODBC', 'UsrLogon','PROD'); DatasourcePassword=CellGetS('ADM_ODBC', 'UsrPassword','PROD'); ODBCOpen(DatasourceC,DatasourceUsername,DatasourcePassword); DatasourceQuery = Expand ('SELECT a,b,c from table;'); ODBCOutput(DatasourceC,DatasourceQuery );
- Excel Version: 13
declanr,
What I need is to have a datasource defined (datasource, user, password, query) to support a TI process.
At this moment I did it normally using the wizard but in the future I will need to do it by code in prolog since I will need to get the user and pass form another cube.
Yes, which is why I asked.jviegas@bi4all.pt wrote:declanr,
The following as the name suggests are to do with setting a datasource:
DataSourceType
DataSourceUserName
DataSourcePassword
DataSourceQuery
The following are not:
ODBCOpen
ODBCOutput
ODBCClose
You do not need them.
- Excel Version: 13
Uhmmm
Can I use "ops"
Thanks for the extra learning minutes... As I said before I never had to do it like this since I always got a service account to do this.
New challenges more learning
Again thanks for checking this and for the time. Going to change this.
Kind Regards,
Jorge
Can I use "ops"
Kind Regards,
Jorge
