I was looking at the STATS cube in tm1 to find out the memory usage of different cubes and I came across something like this.
Number of Populated String Cells 185,508
Number of Populated Numeric Cells 5,538,184
Number of Fed Cells 3,353,369
Memory Used for Feeders 134,217,728
Memory Used for Input Data 268,424,192
Total Memory Used 402,641,920
I can see that the number of populated cells is more when compared to number of fed cells, do this mean that there is some underfeeding in my cube?
Please suggest!
Thanks.
}STATSbyCUBE in TM1
Re: }STATSbyCUBE in TM1
You can't tell from that information whether there is underfeeding.
The populated numeric cells are the white cells at base level in the cube.
The fed cells are cells that contain a rule and have been fed by feeders in any of the cubes of your TM1 model, towards cells in that cube.
