We've installed Tm1 web 10.2 on a separate server to the TM1 server.
The url on the webserver brings back the Tm1 web login using:
http://localhost:9510/tm1web/ or replacing the localhost with the webserverID.
So all is fine on the webserver, however on the client side, we can't see TM1 web using the http://webserverID:9510/tm1web/
This is what we're getting- Internet Explorer cannot display the webpage
Does anyone know if the port 9510 needs to be opened on the webserver for this to work or does the setting in the config file need to reference the web server?
Thanks very much,
Fionnuala
Tm1 web 10.2 set up but not visible on clients- port #?
rmackenzie
Re: Tm1 web 10.2 set up but not visible on clients- port #?
Have you tested if the port is listening?
Robin Mackenzie
uchow10
you definitely need to open the 9510 port on the webserver assuming your firewall is preventing any inbound/outbound connections not allowed in your firewall rules
Fionnuala
- Version: 9.4.1 FP3 HF4 and 10.2
- Excel Version: 2007 and 2010
Yes, culprit was port 9510. It worked fine after it was opened.
Thanks!
Thanks!
