How to use PublishSubset() Function
VPKR
OLAP Product: IBM Cognos TM1
Version: 10.2.2.4
Post by VPKR »
Hello
I have a requirement where i need to publish a private subset for public access. Since it is not supported through TI process, I need to do it through excel macros.
Can anyone please share me a simple macro to achieve this?
Re: How to use PublishSubset() Function
The easiest way to do this is just stick the private subset in a private view. Then use the PublishView TI function to publish the view along with the correct flag to also publish the private subsets.
Vijji
Version: TM1 9.5.2 10.1 10.2
Excel Version: MS Office 2010
Post by Vijji »
Hello guys,
I was going through this post and referred to TM1 Reference Guide and then came across the following:
PublishView function cannot publish a private view that uses private subsets. All private subsets in a private view must first be published with the PublishSubset macro function.
Link: http://publib.boulder.ibm.com/infocente ... ubset.html
PS: Sorry, I haven't come up with a solution (I am new to TM1) but an observation :)
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Post by BariAbdul »
Hi vijji,This might be relevant to you:
http://www.tm1forum.com/viewtopic.php?f=3&t=4544 Thanks
Vijji wrote:Hello guys,
You are looking at the macro functions, I was talking about the TI function of the same name.
VPKR wrote:Hello
TM1 reference guide wrote: PublishSubset
This is a TM1 macro function, valid only in Excel macros and VBA modules.
This function publishes a named private subset on a server.
If you attempt to publish a private subset for which an identically named public subset exists, you will be prompted to overwrite the existing public subset.
Syntax
PublishSubset(dimension, subset)
dimension
The server-prefixed name of the dimension containing the private subset you want to publish. For example, to publish a subset of the Region dimension on the Finance server, you would pass "Finance:Region" as the dimension argument.
subset
The name of the private subset you want to publish.
As in ....
Application.Run "PublishSubset" "cxmd:Product" "Top10 SKUs"
What more do you need?
lotsaram wrote:As in ....
Well, maybe some comma's would be helpful :-)
Application.Run "PublishSubset", "cxmd:Product", "Top10 SKUs"
VPKR
Version: 10.2.2.4
Post by VPKR »
Hi Lotsaram and Wim Gielis, thanks much for your help.
I created a private subset and i can even able to publish it with my user ID with admin access ( using the template i build using the macro button).
I still need experts assistence in below things:
1) I could not publish any private subset created by other users or even other non-admin users could not publish their private subsets.
2) Another puzzle i have is TM1 allows multiple users to create a private subset with the same name. In this case how does system know which user's private subset to be published?
Your help in this will be highly appreciated.
VPKR wrote:Hi Lotsaram and Wim Gielis, thanks much for your help.
1) You need Admin access, as specified by Alan: http://www.tm1forum.com/viewtopic.php?p=23252
2) Each user has its own folder for private objects in the TM1 data directory. Did you have a look over there?
