hi everyone
recently the ibm release the new edition of spss data mining tool: spss modeler 16
the help document tell us the tool can import the tm1 data, but i tested the connection, but it is always display
how to connect tm1 and IBM dataminer tool- modeler 16
welsonlee
- OLAP Product: TM1 9.4.1
- Version: TM1 9.4.1
- Excel Version: EXCEL 2007
- 屏幕截图_081214_033839_PM.jpg (289.54 KiB) Viewed 2627 times
Re: how to connect tm1 and IBM dataminer tool- modeler 16
Interesting to see this. How did you define your source? If it was a TM1 view, I suggest you export that to a file to see what should be coming through. A common problem is to specify 'skip consolidated values' but (inadvertently) to set one or more dimension subsets to have no base elements.
