Tranction log is not working ,I have enabled all the logging ,I have also gone through the below link and tried the given solution but still no success.
http://www.tm1forum.com/viewtopic.php?p=24585 Appreciate your help.Thanks
Transaction log is not working
BariAbdul
- Version: PAW 2.0.8
- Excel Version: 2019
Re: Transaction log is not working
When you say "no results" are you at least getting the window up? Is it just that no results are being returned within the window?BariAbdul wrote:Tranction log is not working ,I have enabled all logging but still no results,I have also gone through the below link and tried the given solution but still no success.
If so I had this earlier today as well on the same version. The transaction log viewer seems to be flaky in 9.5.2. (While performance monitor is just broken to h3ll; I'm so glad that all of the programming resources have been directed to New! And! Exciting! Java! Front! Ends!)
In short, what happened with me is that I got results, backed some of them out, refreshed, and got no results.
However! I then did a data save and hey presto, I was getting results again. Might be worth a try if yours is the same.
If the window isn't showing at all are you getting any error messages?
BariAbdul
Thanks for the reply Alan.I am able to open window but it is empty ,no result.I will try your solution.Thanks again for the help.
