I am having a cube, one of the dimensions 'Sequence' is just purely numbers from 1 to 100, I want to feed these numbers to one of the measurement Seq_Code in the cube.
It works when I add such line in the rules,
['Seq_Code'] = N:attrn('Sequence', !Sequence, 'Sequence_Alias');
but when I add SKIPCHECK, and tried to add a Feeders statement, it went wrong. These are what I added in the rules,
Feeders;
['Sequence': 'Sequence_Alias'] => DB('CbueName', !Dim1, !Sequence, 'Seq_Code');
Could you please tell me what the correct statement should be? Thank you so very much.
Rules - Feed dimension attribute to a measure cell
Re: Rules - Feed dimension attribute to a measure cell
Can you please provide actual code not pseudo code.
- Version: 10.1
Sure.lotsaram wrote:Can you please provide actual code not pseudo code.
Cube Name: Courses
It has 3 dimensions, 1 Version (2010, 2011, ...)
2 Sequence ( 1, 2, ...100), it has an attribute 'Sequence_Alias' defined
3 Measurements (Seq_Code, Course_ID, Course_Name...)
The rules I wrote,
SkipCheck;
['Seq_Code'] = N:ATTRN('Sequence', !Sequence, 'Sequence_Alias');
Feeders;
['Sequence':'Sequence_Alias] => DB('Course', !Version, !Sequence, 'Seq_Code');
Why are you feeding the Seq_Code value? Is it because you don't want it to disappear on a zero suppress? If that is the case, do you just want it to not zero suppress when one or more of the other measures have a value? In that case you should feed from one of the other measures, not the Alias attribute (which, BTW, would not be recommended).
- Version: 10.1
The column Seq_Code is assigned with numbers to identify each row as being a unique instance. It's going to be used as a lookup to retrive other measures.tomok wrote:Why are you feeding the Seq_Code value? Is it because you don't want it to disappear on a zero suppress? If that is the case, do you just want it to not zero suppress when one or more of the other measures have a value? In that case you should feed from one of the other measures, not the Alias attribute (which, BTW, would not be recommended).
Hope it makes sense.
Thank you.
You didn't answer my question. Why are you feeding it?nayitian wrote:The column Seq_Code is assigned with numbers to identify each row as being a unique instance. It's going to be used as a lookup to retrive other measures.
- Version: 9.52 - 10.1
- Excel Version: 14.0.6129.5
If I gather what you are trying to do correctly:
You would like to automatically feed the Sequence # FROM an Number Type Attribute named: 'Sequence_Alias' on the Dimension:Sequence to the Cube Value:
'Seq_Code' in Measure.
In Terms feeding it
Will Error because Sequence_Alias is an attribute not an element.
The classic style feeder wouldn't work here since you would be WAY over feeding.
To drive to Tomok's point: You need to feed it something else to denote a value flag:
Or alternatively, if you don't want a sequence code or another value to flag it you could not feed it.
On the other hand if you just want a feeder that works for feeders sake:
['Seq_Code'] => DB('Sequence', !Version, !Sequence, 'Seq_Code');
I think is what you are looking for.
In Terms feeding it
The point I was trying to make is that feeding is not necessary for what he wants to do, use the value as a lookup into another calculation. A non-fed, rule-calculated cell will still have a value, regardless of its status of being fed. The only thing feeding will do for him is to stop the Seq_Code measure from being zero suppressed when it is being used as a column or row header in a view or active form.
- Version: 10.1
Carl Lonsdale wrote:If I gather what you are trying to do correctly:
In Terms feeding it
Hi, thanks so very much. This helps a lot, and it's exactly what I want to learn and know.
