TM1Cube.setCellValue against a consolidated cell
isakk3
OLAP Product: IBM Cognos TM1
Excel Version: 2011
Post by isakk3 »
Hello, TM1 expert,
I'm a beginner of Cognos TM1. I'm now trying to use TM1 Java API and had the subject question.
When I tried to call TM1Cube.setCellValue() against a consolidated cell, I got an error message ObjectSecurityNoWriteRights although I expected another error such as UpdateNonLeafCellValueFailed. Why I got ObjectSecurityNoWriteRights? Can I overwrite a consolidated cell by setting such a write right?
Isao
jim wood
Version: PA 2.0.7
Re: TM1Cube.setCellValue against a consolidated cell
Post by jim wood »
In TM1 the oly way you can overwrite a consolidated value is with a rule. as for the error message you're getting I'm no API expert but I'm sure the likes of Alan will be able to help you out with that,
isakk3
Excel Version: 2011
Post by isakk3 »
Hi, Jim,
Thank you very much for your comment!
Isao
Gabor
Version: [2.x ...] 11.x / PAL 2.1.13
Excel Version: Excel 2016-2021-365
Post by Gabor »
You could do data spreading to the leaf elements below that consolidation.
jim wood
Version: PA 2.0.7
Post by jim wood »
Good point Gabor. That's one way round it. Once you start opening up the children there's a fe wspreading options and some others as well.
isakk3
Excel Version: 2011
Post by isakk3 »
Hi, Jim & Gabor,
Thank you for your suggestions.
Regarding my question about ObjectSecurityNoWriteRights, I confirmed TM1Cube.setCellValue() returns the same error when calling it against a calculated cell as well as a consolidated cell.
Isao
