TI error with the csv file datasource
kiss351523
Version: 9.5
Excel Version: 2007 and 2003
Post by kiss351523 »
Dear All,
I beated by a strange error from TM1 Process.
Its a simple process, data source is csv file, the file localed in a LAN PC, TM1 process colud preview the data, but, when i run the process with admin account in TM1,
a error popped, Colud not open the datasource.
Please help me with this, thanks a lot!!!!
Check the img attachement.
Re: TI error with the csv file datasource
kiss351523 wrote:Dear All,
The process isn't previewing the data; you are, on your client machine. It's entirely possible that you can see a data source which your login has access to, but which the login that the TM1 server is running under cannot. Doubly so if the TM1 server is being run under the local system account on the server.
Always remember that although you create and edit a process using your own credentials, what matters when you try to run it is what the network permissions of the server's account are.
If possible, log on to the server box using the same login that the TM1 server is running under and see whether you can still access the file on that network share. My bet is that you won't be able to. If the server program is running under a local system account, replace it with a domain account that has the appropriate permissions to that network share. If it's already under a domain account, have your network admins assign that account to a group which has permissions to that share.
kiss351523
Version: 9.5
Thanks to Alan, It's entirely possible that you can see a data source which your login has access to, but which the login that the TM1 server is running under cannot., in the TM1 server, there are two account for TM1 service, the accounts for TM1 Admin Server and TM1 instance server. which account would be assigned to?
kiss351523 wrote:Thanks to Alan, It's entirely possible that you can see a data source which your login has access to, but which the login that the TM1 server is running under cannot., in the TM1 server, there are two account for TM1 service, the accounts for TM1 Admin Server and TM1 instance server. which account would be assigned to?
The exact path depends on which version of Windows your server is running under, but if you right click on the Computer icon and select "Manage" you should eventually get to the list of Windows services. Find the TM1 server service, right click on it and select "Properties". You'll find what you're looking for on the "Log On" tab.
deepakjain2020
Version: 9.5.2; 10.2.2
Post by deepakjain2020 »
I am not aware of what impact it will have when we replace forward slash (/) with backward slash (\).
"\\servername/folder/file" with "\\servername\folder\file".
I have always been using backward slash.
Deepak Jain
