I have a problem in a static form published on tm1web.
When I try to send a data with decimal from the web, this last one is not send to the cube.
For exemple if the data is "20", everything is OK, whereas if it is "20,19" the data is not send and remain as 0 (or the previous data).
Does anyone have a solution or a tip ?
Thank you for your help.
Express 10.2 - data not send from web
Re: Express 10.2 - data not send from web
Try enterimg 20.19 to see if it is an issue with what it deems to be your decimal separator. I believe there was a listed bug with using the comma through tm1 web 10.2 but I thought that was fixed with the first fixpack.
Are you on cx 10.2 fp1 or just the base install?
rafale29
- Version: 9.4 - 9.5.2 - 10.1.1
- Excel Version: 2007 - 2010
Hello Declarn,
The server language is setup as using "," for decimal separator. So on, if I try to input "20.19", I have an information popup informing that using "," is compulsory.
About the FP1, I have to check this point. I will inform you as soon as possible.
- Michel Zijlema
- OLAP Product: TM1, PALO
If you're using Internet Explorer you need to check your IE regional settings. For more info see this thread.
Michel
Michel
