TM1 websheet - SUBNM work only in Administrator User
Motyl
- OLAP Product: Cognos
- Version: 10.1
I have big problem. I have websheet's there function SUBNM("CXMD:dimName";"";"") works only in administrator Login. In other user there's not triangle to start window where i can choose valuse from list.
Please Help
Please Help
Re: TM1 websheet - SUBNM work only in Administrator User
I'm not sure what a triangle has to do with it, nor the semi-colons in the formula. However if a SubNm works on an Admin login but not on other logins, wouldn't this normally suggest that you have security on the dimension and that the other group(s) do not have the necessary security access?Motyl wrote: I have big problem. I have websheet's there function SUBNM("CXMD:dimName";"";"") works only in administrator Login. In other user there's not triangle to start window where i can choose valuse from list.
Not everyone on earth uses a comma as the separator for arguments in a formula.Alan Kirk wrote:nor the semi-colons in the formula
Belgians generally use ; as a separator.
Yes, it's annoying
Such eccentricity is allowed in Belgium.Wim Gielis wrote:Not everyone on earth uses a comma as the separator for arguments in a formula.Alan Kirk wrote:nor the semi-colons in the formula
Yes, it's annoying
The chocolate more than makes up for it.
- jim wood
- Version: PA 2.0.7
Don't forget the fine fruit beers and the mussels!!
- Michel Zijlema
- OLAP Product: TM1, PALO
Mussels from Brussels, eh? I thought it was muscles from Brussels...jim wood wrote:Don't forget the fine fruit beers and the mussels!!
- jim wood
- Version: PA 2.0.7
You're all welcome to taste the mussels and other fine stuff in Belgium! *Beer*
We can enjoy these nice things in life while also chatting about TM1
- jim wood
- Version: PA 2.0.7
Where's the like button on this site when you need it???Wim Gielis wrote:You're all welcome to taste the mussels and other fine stuff in Belgium! *Beer*
Does this suggest that TM1 isn't one of the nice things in life?Wim Gielis wrote:You're all welcome to taste the mussels and other fine stuff in Belgium! *Beer*
I'm sorry Declan, I take back the previous post.
Only 3 characters in total but such a nice thing
No, I didn't mean IBM, but TM1.
