Not sure if anyone else had this issue in version 10.1.1 of TM1web, when trying to export a 64 page to PDF or Snapshot to Excel. You get the following error message " Number of sheets to export exceeds maximum allowed"
Anyone have a solution ?
thanks
TM1web v 10.1.1 - Number of Sheets to Export Exceeds maximum
- Version: 9.5.1
- Excel Version: Excel 2007
- jim wood
- Version: PA 2.0.7
Re: TM1web v 10.1.1 - Number of Sheets to Export Exceeds max
I've only ever had this when accidentally spliting the export in to too many pages. How have you defined your export?
- Version: 9.5.1
Seems to fail when our accountant tries to Export to PDF or Snapshot to Excel when Entity is select (and it shows 32 elements), note this one of the smallest divisions. but is the accountant select period (1 period) it's fine, no issues. hope that helps.
- jim wood
- Version: PA 2.0.7
What options are they selecting when they export? Are they trying to split it?
- Version: 9.5.1
No splitting. How do they spilt ?
- jim wood
- Version: PA 2.0.7
Select dimension titles. That will create seperate pages. If you don't select any it will export as is.
- Version: 9.5.1
thanks, i'll get them to try that.
