I am trying to create dynamic subset using below MDX,but it is not working.
Need suggestions on this.
SubsetCreateByMDX('WaferSize_Item',ELPAR('Product_Dim','{FILTER( {TM1FILTERBYLEVEL( {TM1SUBSETALL( [Product_Dim] )}, 0)}, [Product_Dim].[SIZE] = "200")}'), 1));
Here "200" is Attribute value of products and wants replace with user input variable.
Sathish
Dynamic Subset using MDX
- Version: 9.4 and 9.5
Re: Dynamic Subset using MDX
The ELPAR section of your code isn't MDX and the subsetcreatebymdx function only accepts an mdx statement so that won't work. I can't remember off the top of my head how you get element parents in MDX but the following should work.sathishh.mk wrote:Hi,
Sathish
SubsetCreateByMDX ( 'WaferSize_Item_temp', sMDX, sDimName );
SubsetCreate ( sDimName, 'WaferSize_Item' );
iCount = 1;
iMax = SubsetGetSize ( sDimName, 'WaferSize_Item_Temp' );
While ( iCount <= iMax );
sElement = SubsetGetElementName ( sDimName, 'WaferSize_Item_Temp', iCount );
sParent = ElPar ( sDimName, sElement, 1 );
If ( sParent @<> '' );
SubsetElementInsert ( sDimName, 'WaferSize_Item', sParent, SubsetGetSize ( sDimName, 'WaferSize_Item' ) + 1 );
EndIf;
iCount = iCount + 1;
End;
SubsetDestroy ( sDimName, 'WaferSize_Item' );
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
I'm not sure ELPAR works in an MDX statement. Try "parent" instead.
Second comment: what if the FILTER returns more than one element as result? I think the 'Parent' function needs one element of which you want to query the parent.
UPDATE: just reading through the post of declanr - this is a fine solution as it also resolves the problem if in the filter you receive elements of which parents are not the same.
That's the one I was trying to think of (and it couldn't have been a more obviously named onemvaspal wrote:Hi
