TM1 process
vins
TM1 process
Post by vins »
When the process is executed by myself using tm1 web , it takes less than 10 seconds. When the same process is executed by other user, it takes around 2 minutes and some time "Operation failed" message is received.
The process runs in background and gets executed.
I searched a lot in Google but was not able to anything concrete. Can you please throw some light on the reason behind it.
Vinay
Re: TM1 process
Would need to see the code or at least know what its doing as per the request for assistance guidelines.
vins
Re: TM1 process
Post by vins »
The code copies the value from one intersection to another intersection.
qml
Excel Version: 2007 - 2016
Re: TM1 process
Post by qml »
vins wrote:I searched a lot in Google but was not able to anything concrete.
I'm afraid you'll get the same result here if you refuse to follow the guidelines and to provide all the concrete details.
Kamil Arendt
