TI error:URGENT
mincharug.shulft
TI error:URGENT
The below script is in data tab in TI :
CubeName=’sale’;
vTTT_sale_rupees= StringtoNumber(TTT_sale_rupees);
IF(vTTT_sale_rupees <>'');
CellIncrementN (vTTT_sale_rupees, CubeName, p1 , t1 , time1 , ‘Sales_Measures’ ) ;
ENDIF;
Where my “TTT_sale_rupees” values are coming from oracle like this
120.0023
100.2002
201.01002
And I am getting the attached error while I am saving,can you please help as its urgent for me
CubeName=’sale’;
ENDIF;
120.0023
100.2002
201.01002
- The below script is in data tab in TI.docx
- (18.06 KiB) Downloaded 382 times
Re: TI error:URGENT
Have you provided your EXACT code?
The screenshot suggests it actually contains "ddd_sales_dollars" and I can't see that in what you've provided.
mincharug.shulft wrote:The below script is in data tab in TI :
CubeName=’sale’;
ENDIF;
120.0023
100.2002
201.01002
mincharug.shulft
Re: TI error:URGENT
The following is correct one:
vDDD_SALES_DOLLARS= StringToNumber(DDD_SALES_DOLLARS);
IF( DDD_SALES_DOLLARS @<> '');
CellIncrementN ( vDDD_SALES_DOLLARS, CubeName, CMA_ID , CP_Contracts , PRODUCT_BRAND_DSCR , vTIME_DATE_DAY , CP_Sales_Measures ) ;
ENDIF;
Where my “DDD_SALES_DOLLARS” values are coming from oracle like this
120.0023
100.2002
201.01002
200.9090
ENDIF;
120.0023
100.2002
201.01002
200.9090
mincharug.shulft
Re: TI error:URGENT
IF( vDDD_SALES_DOLLARS @<> '');
ENDIF;
120.0023
100.2002
201.01002
200.9090
ENDIF;
120.0023
100.2002
201.01002
200.9090
Re: TI error:URGENT
Well as a starting point:
VDDD_sales_dollars @<>
Is illogical since it is not string but a number as per your stringtonumber function.
mincharug.shulft
Re: TI error:URGENT
Thanks even i have used numbertostring though getting same error.actually my data is like this
120.0023
100.2002
201.01002
200.9090
120.0023
100.2002
201.01002
200.9090
Re: TI error:URGENT
I don't think you've actually grasped my previous point.
A snapshot of your variables tab could help.
mincharug.shulft
Re: TI error:URGENT
You are doing stringtonumber on something that is already a number....
mincharug.shulft
Re: TI error:URGENT
Mean to say i have to use Numbertostring or not required and are not required both(numbertostring and stringtonumber).
if i use @<> attached geting the attached error.
- Doc8.docx
- (18.86 KiB) Downloaded 315 times
Re: TI error:URGENT
Wouldn't you be better changing the variable type of DDD_SALES_DOLLARS to numeric and not doing the conversion in your code? And, why test for zeros (or '' as you have written it)? Just cellincrement the value - you don't need the if test at all.
mincharug.shulft
Re: TI error:URGENT
Thanks lot david ur valuable reply BUT
As we are getting the some zero values for that i want to ommit the zero values and only non zero values i plan to load it as this process is talking 10 hours to load completly as table is having 1+ crores records.so this is approach correct?
Re: TI error:URGENT
I don't know. Is it urgent?????mincharug.shulft wrote:Thanks lot david ur valuable reply BUT
Re: TI error:URGENT
Probably a good idea to adjust the query to exclude zero rows before they reach TM1.
Probably also a good idea to explain what a crore is ie http://en.wikipedia.org/wiki/Crore - I don't believe it's a well known term outside South Asia.
Re: TI error:URGENT
Also... use this site: http://translate.google.com/David Usherwood wrote:Probably also a good idea to explain what a crore is ie http://en.wikipedia.org/wiki/Crore - I don't believe it's a well known term outside South Asia.
Whatever you do, it cannot be less clear than what you posted above.
