Removing alias from subset via TI
M1_A1
Version: 10.1.1
Post by M1_A1 »
Does anyone have a way to remove an alias from a subset via TI?
It is easy to add an alias using the SubsetAliasSet but I do not see a way to remove it. So far I have tried using SubsetAliasSet and set the alias as '' . That resulted in an error.
Running 10.1.1.
Thanks!
Re: Removing alias from subset via TI
I just delete and rebuild the subset in TI; that will make it use the default name.
If you don't need to use TI just untick it in the subset editor then save it.
M1_A1
Version: 10.1.1
Post by M1_A1 »
Thanks for the reply.
I do not want to destroy the subset in case it is used in a view. I am setting this up so non-admins can maintain some public subsets. So the manual process of un-checking the alias will not work.
Thanks again.
M1_A1 wrote:I do not want to destroy the subset in case it is used in a view. I am setting this up so non-admins can maintain some public subsets. So the manual process of un-checking the alias will not work.
Then you're out of luck. The two options given are the only way.
M1_A1
Version: 10.1.1
Post by M1_A1 »
Here is the work around I developed: I add an temp alias , set the temp alias in the subset , and then delete the alias
This seems to work.
AliasName= CellGetS(sCube, vDim, zSys_Subset_List, 'Alias', 'Element');
IF(AliasName@<>'' & DIMIX('}ElementAttributes_' | vDim, AliasName)<>0);
SubsetAliasSet( vDim, vSubsetName, AliasName );
ElseIf(AliasName@='');
AttrInsert(vDim, '' , 'Temp_Alias' , 'A');
SubsetAliasSet( vDim, vSubsetName, 'Temp_Alias' );
AttrDelete(vDim, 'Temp_Alias');
EndIf;
rmackenzie
Post by rmackenzie »
In the TI that processes the subset, you could create a new, temporary subset and read all the elements that exist in the public subset into the new subset. This won't have the alias attached; it can be used for the duration of the TI and deleted at the end. This way, you can allow your users to maintain the public subsets and still manipulate copies of them during the TI processes without upsetting the users functionality.
Robin Mackenzie
