TM1 if statement issue
ssadoglu
OLAP Product: tm1
Post by ssadoglu »
I've been using TM1 10.2.I'm newbie. I have a problem related to the if function.
Here is my rule :
['Brüt Kar' ] = (DB('Satýþ ve Maliyet', !Aylar, !products, 'Satýþ', !Senaryolar, !Yýllar, !Ülkeler, !Stroes)
              + DB('Satýþ ve Maliyet', !Aylar, !products, 'Maliyet', !Senaryolar, !Yýllar, !Ülkeler, !Stroes));
['Sales' ] = N: DB('Satýþ ve Maliyet', !Aylar, !products, 'Satýþ', !Senaryolar, !Yýllar, !Ülkeler, !Stroes);
['Gider' ] = N: DB('gider', !Aylar, 'Toplam Giderler', !products, !Stroes, !Senaryolar, !Ülkeler, !Yýllar);
['Toplam Maliyet'] = N: DB('Satýþ ve Maliyet', !Aylar, !products, 'Maliyet', !Senaryolar, !Yýllar, !Ülkeler, !Stroes);
['Net Kar' ]  = N: (['Sales' ] - ( ['Gider' ] + ['Toplam Maliyet' ] ));
['Net Zarar'] = N:  IF(['Net Kar'] >0, 0, CONTINUE);
['Net Zarar'] = N:  IF(['Net Kar'] <0, ['Net Kar'], CONTINUE);
Net Kar is less than zero value. Net Kar would be zero value and Net Zarar would be equal first value of "Net Kar".
E.g :
First statement :
Net Kar :- 1200
Net Zarar : NULL
Second statement:
Net Kar : 0
Net zarar : -1200
Thanks in advance,
Kind Regards,
Re: TM1 if statement issue
Post by David Usherwood »
Your first rule sets Net Zarar based on Net Kar being positive, if not the second rule applies. Net Kar won't be affected by either rule as it's set in the line above. Remember rules are declarative, not procedural (like Excel formulae) - the first assignment which applies is the one which is used.
ssadoglu
OLAP Product: tm1
Post by ssadoglu »
David Usherwood wrote:Your first rule sets Net Zarar based on Net Kar being positive, if not the second rule applies. Net Kar won't be affected by either rule as it's set in the line above. Remember rules are declarative, not procedural (like Excel formulae) - the first assignment which applies is the one which is used.
Hi David,
This rule isn't working. So I mean finally Net Kar must be zero value. But , it's not working. I want to do like below. if I work above "if condition" I'm getting the following result.
Net Kar : - 1200
Net zarar : -1200
Finally , I want to do :
if Net Kar < 0 ;
Net Kar : 0
Net zarar : -1200
Thanks , regards,
But you set Net Kar in the first rule and you can't then change it later - in fact your later rules only affect Net Zarar anyway. Be clear - Rules are declarative not procedural - once a rule applies that's it.
ssadoglu
OLAP Product: tm1
Post by ssadoglu »
David Usherwood wrote:But you set Net Kar in the first rule and you can't then change it later - in fact your later rules only affect Net Zarar anyway. Be clear - Rules are declarative not procedural - once a rule applies that's it.
Ok. How can I modify my rule? I'm a few confused.
Thanks & Regards,
What's the business problem you are trying to solve?
ssadoglu
OLAP Product: tm1
Post by ssadoglu »
David Usherwood wrote:What's the business problem you are trying to solve?
Hello David,
OK. Like you said you are correct. I've changed the first line within rule. I've defined different column except "Net Kar". it works.
Kind regards,
roy2087
OLAP Product: cognos tm1
Version: 10.1.1
Post by roy2087 »
How about using this rule:-
['Net Zarar'] = N: IF(['Net Kar'] > 0, 0 , ['Net Kar'] );
Roy.
