I have an access database where I have drill's setup from TM1 to show detail. It appears that there is an open ODBC connection keeping the database locked. I do not think it is the TM1 server because all TM1 services run under user tm1app and the ODBC lock is from user admin.
So I guess my question is to confirm my theory.
Does the TM1 ODBC connect with the service user,"tm1app", or are they run by a different user,"admin"?
* I also double checked. The DSN ODBC Connection is NOT setup with a fixed user and password.
ODBC Locking Database Issue
- Eric
- Version: 9.4
- Excel Version: 2003
Eric
Eric
- Steve Rowe
Re: ODBC Locking Database Issue
Hi Eric,
I had a lot of trouble with TM1 locking an access DB it was loading data from. It seemed that often a lock was left behind or I would get strange out of memory issues being reported from ODBC.
I was not able to solve this and in the end I had to restart the box to clear the issues. There is a thred on this somewhere but I can't find it.
Martin Erlmoser
- Version: 9.1.4 FP1
we have this problem also with access dbs,.. recycle the server and it works again
but sorry i don't have a better solution
- Eric
- Version: 9.4
Found out a few things.
1) If you open the .ldb file in notepad it tell you all of the users that are connected
2) ODBCClose(); Does not work
Still no answer other than reboot. Still looking though the "jet engine" for something.
Eric
Eric
Just a couple of random, untested thoughts... often locking problems in Access result from a database being opened in Exclusive mode. Might be worth checking both the default open mode in the .mdb (Tools -> Options -> Advanced) and the DSN Configure... -> [Options] and make sure that the default mode is Shared and the Exclusive box is unchecked, respectively.Eric wrote:Found out a few things.
