I am using the following function in my Active Form. Is there is a way to get only leaf level n elements of the Subset displayed in the Active Form?. The subset I am using has a consolidated element.
TM1RptRow(ReportView, Dimension, Subset, SubsetElements,
Alias, ExpandAbove,MDXStatement, Indentations, ConsolidationDrilling)
regards,
Abi
TM1RPTRow
Re: TM1RPTRow
Why can't you use a different subset without the consolidated elements OR some mdx code that doesn't include the consolidations?
Re: TM1RPTRow
Just use the MDX argument rather than the Subset argument in the TM1RptRow formula. You could even use the subset as the base of the MDX expression to filter by level for 0 level elements (this will work fine so long as the subset doesn't share a name with an actual element in the dimension).
rmackenzie
Re: TM1RPTRow
If your dimension is called e.g. Business_Unit and the consolidation is e.g. All Business Units then the TM1RPTROW formula should read:Abinaya wrote:Is there is a way to get only leaf level n elements of the Subset displayed in the Active Form?. The subset I am using has a consolidated element.
=TM1RptRow(ReportView, Dimension, "", "", "", 0, "{TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER( {[Business_Unit].[All Business Units]}, ALL, RECURSIVE )}, 0)}")Robin Mackenzie
Abinaya
- Version: 9.5.2
- Excel Version: 2003
Re: TM1RPTRow
Thanks. This really worked well.rmackenzie wrote:If your dimension is called e.g. Business_Unit and the consolidation is e.g. All Business Units then the TM1RPTROW formula should read:Abinaya wrote:Is there is a way to get only leaf level n elements of the Subset displayed in the Active Form?. The subset I am using has a consolidated element.Assuming that ReportView and Dimension are named ranges - if not, replace them with the correct cell references.Code: Select all
