I'm having problem connecting to performance modeler for a blank new TM1 model. When I tried to connect I got 'unable to connect to planning service'. Has anybody else run into this problem or able to provide a clue where to look? We are testing this on Windows7 Professional SP1 as server.
I saw there was a topic similar to this for TM1 10.1 but not for new model (something to do with corrupt view of existing TM1 model).
Thanks!
TM1 10.2 Performance Modeler error
Re: TM1 10.2 Performance Modeler error
Make sure that you've configured things in the Applications Portaloo first as per RobMc's reply to mine in this thread (don't get me started on what a stupid piece of design that is), and that you don't have the same configuration issue that I mentioned in my subsequent reply.MKusuma wrote:I'm having problem connecting to performance modeler for a blank new TM1 model. When I tried to connect I got 'unable to connect to planning service'. Has anybody else run into this problem or able to provide a clue where to look? We are testing this on Windows7 Professional SP1 as server.
- Version: 10.1
Alan,
I had done exactly what you did before I posted here for the first time:
1. Setup the application portal
2. Set up root directory for .cfg file and then data and log folders in that root directory
and after going back and forth with IBM Support where I was told 'Windows 7 Professional is not supported to be TM1 10.2 server' and 'they will not look into this because Windows 7 Professional is not supported', I finally gave up and close the PMR.
Fortunately, I didn't get the same issue in Windows 2008 R2, which just happened to be supported as TM1 server.
http://publib.boulder.ibm.com/infocente ... rm=Windows
- Version: 2.x
- Excel Version: 36x
Not supported doesn't mean it will not work.
I have the full 10.2 environment running in Win 7 (64bit though) including Cognos BI stack.
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
Given that the standard IBM development machine has 64 bit Windows 7 Pro installed I would be very surprised if it didn't work. The OS version is not your problem.
