I am using Cognos 9.5.2 with Cognos 10 BI security
We create the groups in BI and import to TM1 and assign access for those groups to cubes and dimensions
I have dimensional security Country wise, scenario wise and the measure dimension wise
My users sometimes close the forecast and they wanted to open only for few countries
LA_Brazil, LA_ARG , LA_MEX , LA_PremLoss , LA_Expense are the group names
LA_Brazil , LA_ARG, LA_MEX are mapped to country as well as Scenario
LA_premLoss, LA_Expense are mapped to scenario and elements of the Measure dimension
So,this wat i do
my Country and measure dimension security remain untouched
LA_BRA LA_ARG LA_MEX
brazil business units WRITE
argentina business units WRITE
mexico business units WRITE
Measure dimension
LA_PremLoss LA_Expense
GWP WRITE WRITE
i only alter the scenario dimensional security , For eg, i want only the argentina users to make changes,i change like this
LA_BRA LA_ARG LA_MEX LA_PremLoss LA_Expense
FQ1-M3 READ WRITE READ WRITE WRITE
So the argentina users have write access to the respective scenario
but the other county guys also have access to change the values, eventhough one group have read access
Eg;, brazil user , LA_BRA has read REad access to FQ1-M3 and the LA_PremLoss has Write access to FQ1-M3
The brazil user belong to both the LA_BRA and LA_PremLoss groups
Does write access of one group overrides the read access of another group in diemnsional security
Can anyone help me on this because i cannot do testing also as i dont have any additional id's and its a long process to get them and assign security acess after confirmation and aouthorizations
Guru
Does Write access override Read access in dimension security
guru1988fortm1
- Version: PA 2.0.3
- Excel Version: Micrsoft Excel 2010
Re: Does Write access override Read access in dimension secu
First of all, it's nice to see a question which contains all of the actual detail of the problem instead of the more common, "suppose I have groups A and B, and suppose..."
It's a pain that the phpBB software that the forum runs on doesn't include table functionality, but if I understand your question correctly the grid of security looks like this:
And the Brazil person would be a member of LA_Brazil, LA_PremLoss and LA_Expense, while the Argentine user would be a member of LA_ARG, LA_PremLoss and LA_Expense.
In that case, yes, you are correct in your assumption. TM1 runs on a least restrictive security model, meaning that if you pick up write access from one group it doesn't matter if you have only Read access in other groups. Consequently the Brazil person's membership of LA_PremLoss and LA_Expense will give them write access to FQ1-M3.
The solution is pretty simple; don't let LA_PremLoss LA_Expense assign any access in the Scenario dimension. It doesn't need to; that's not its job as I read your question. Its job as I read it is to assign access to the Measure dimension. If you want to assign a combination of country / scenario access, do that entirely through the three country groups.
LA_Brazil LA_ARG LA_Mex LA_PremLoss LA_Expense
Country
Brazil WRITE
Argentina WRITE
Mexico WRITE
Scenario
Measure
GWP WRITE WRITEIn that case, yes, you are correct in your assumption. TM1 runs on a least restrictive security model, meaning that if you pick up write access from one group it doesn't matter if you have only Read access in other groups. Consequently the Brazil person's membership of LA_PremLoss and LA_Expense will give them write access to FQ1-M3.
guru1988fortm1
- Version: PA 2.0.3
Hi Alan,
Your understanding is correct, this is the actual design of my TM1 Security
Also, Thanks for pointing out that the Write access of one group will override the READ access of another group to the element in the same dimension
(My understanding was complete opposite to this prior )
It really did work , when i removed the groups LA_PremLoss and LA_Expense from the Scenario security. i cleared those cells,
And when i made LA_Brazil as Write, only brazil user can have access and for others , it is grayed out
But i wanted to extend my security a bit more
Say , In brazil, i have two different types of users, premLoss Users and Expense Users
so, is there a possibility to limit the users further more
Provided that, GWP is not the only element in measure , it has around 150 elements in it
And
we always have two scenarios open in our TM1, one willl be Budget(done for 5 years) , other is forecast(done for an year), so we cannot make the measure dimension as read/write
Is there any other possibility to achieve this with my design
Guru
And
Guru
