Unattented Install Cognos Express 10.1
homebunny
Version: 9.1 SP4
Excel Version: 2002
Post by homebunny »
Has someone discovered a good way to deploy the Excelerate client to muliple machines?
We are using a tool to deploy software but i can't figure out the command line switches.
Re: Unattented Install Cognos Express 10.1
If you just want to put Xcelerator client on a load of machines without going through all the annoying GUI interface, the most simple method (IMO) is to copy and past the program files directory and then open up the tm1p.xla file. On occasion you need to manually register some DLLs depending on user rights etc but if you find that to be an issue you can just set up a batchfile to do the whole job.
homebunny
Version: 9.1 SP4
Excel Version: 2002
Post by homebunny »
This works perfect.
There is a side-effect for admins:
This brings back the old way off adding new users to TM1.
