Hi Friends,
I have bit Knowledge on Report Studio, FM (Relational ), I want to learn the TM1, Please tell me what are the Prerequisites to learn TM1?
Which areas do i need to learn & Focus more to get more Career Opportunities?
Kumar
What are the Pre requisites to learn the TM1?
helpcognos
- Version: 10.2
Re: What are the Pre requisites to learn the TM1?
Common Sense + TM1 Software + Time
Search the forum for such topics as it seems to get asked fairly regularly and on occasion people do post helpful responses (such as a link to trial software), also check the FAQ.
Tm1andTm1
- Version: 10.2
Declan,
Common sense is not mandatory prerequisites......
helpcognos
- Version: 10.2
Hi Friends,
I mean, Which technical Knowledge is needed prior to Learn TM1, Does it require any MDX Knowledge to learn?
Many Thanks,
Kumar
Many Thanks,
Kumar
kaazimraza
- OLAP Product: TM1, SSAS, Power BI
Hi Kumar,helpcognos wrote:Hi Friends,
Many Thanks,
Kumar
From a technical point of view, you need to understand how OLAP works, and have an idea about dimensions, cubes or just give a read through to star schema. From a non-tech/functional point of view, if you have studied a finance or accounting course in college, it should be good enough to get you started, with most of the of examples out there.
Other than the above, you need to have the hunger to learn + time + TM1 software.
Kaz
Kaz
nedcpatm1
- Version: 10.1.1
Check out the prerequisites for IBM TM1 certification, and also web search TM1 developer/admin job descriptions to get some ideas.
if you search for the all sparks cube talked about by legends and activate it, you can make any business system come to life
Yeon
