Dear all,
I've a question on "TM1 Mobile Contributor"TM1 10.2.
I've tried to find out in the web wether this tool is only for planning, or if this is also for just viewing cubes or reports e.g. Wasn't very successful. I always find info like " Receive notifications of plan review actions and changes"...
But is normal cube viewing or Report viewing (with DBRW formulas) also possible?
Do I need to install/configure anything special on the server to use this App on my ipad?
Thank you all
TM1 Mobile Contributor only for planning?
PlanningDev
- Version: 2.0.5
Re: TM1 Mobile Contributor only for planning?
The current answer is no the TM1 Mobile App is only capable of viewing cube views that are built into a TM1 Application.
Slice and Dice/Drag and Drop is not possible like the web cube viewer. Websheets do not render, etc. Its current state is very limited.
andrewsg
- Version: 10.2
- Excel Version: NA
Currently the app does not support rendering of web sheets. Slicing and manipulation of the view IS supported. Press and hold on the context items in the shelf - then drag/nest to desired position. Tap the context item will present a list of members to slice on in the titles area of the shelf.
