I have a chore with 3 process (below). If i run Process 1 and process 2 separately they are running fine but it i put them in a chore and make it multicommit they are running for hours (22-33hrs) . Total time of chore should be not more than 16min. (process1 6min, Process2 10min ). I noticed the save data chore is overlapping this chore.
Chore Processes:
1.updating actuals to cube A,
2. a. Update actuals from Cube A to B b. Update forecast numbers from Cube F to Cube B
Does my multicommit mode could cause this issue or save data chore is causing this issue ? Can any one focus some light in which direction i should be investigate ?
TM1 10.1.1
ParallelInteraction=T
Thank you all taking time.
Multicommit Chore runtime issue
- vinnusea
- Version: 10.2
Vinnusea
Vinnusea
TableManagerOne
- Version: 10.1 RP1 FP1
- Excel Version: 2003 SP3
Re: Multicommit Chore runtime issue
Sounds like it could be the SaveDataAll cache issue referenced here.
User "whitej_d" suggested invalidating upstream cubes to set the cache right again. Perhaps you could insert a 4th process (just after the process containing the SaveDataAll) to force an invalidation?
failurehappening
Does the same thing happen when the chore is run manually compared to when it is scheduled?
RHR
BariAbdul
- Version: PAW 2.0.8
- Excel Version: 2019
[quote="vinnusea"]Hi,
The OP clearly mentions when the process run manually it throws no error.Thanks
Edward Stuart
- Version: All
- Excel Version: All
and failurehappening means if you run the chore without overlapping with the SaveDataAll chore does it take 22-33 hours
failurehappening
Yes I understood that when the processes are run manually they run ok, but I asked about the chore being run manually not the processes. It's an important difference...BariAbdul wrote:vinnusea wrote:Hi,
http://www.tm1forum.com/viewtopic.php?f=3&t=9631
RHR
BariAbdul
Thanks for link which explains the nuance between the two.Appreciate it.failurehappening wrote:Yes I understood that when the processes are run manually they run ok, but I asked about the chore being run manually not the processes. It's an important difference...BariAbdul wrote:vinnusea wrote:Hi,
- vinnusea
- Version: 10.2
Yes, I have disabled the savedata chore and still the issue continues. Tomorrow am planning to split the chore into 2
Chore1:
Chore2:
1.Update actuals from Cube A to B
2.Update forecast numbers from Cube F to Cube B
Hope this helps.
Chore1:
Chore2:
Hope this helps.
Vinnusea
Vinnusea
