An unexpected error was generated by a ti process
Kazêh
Post by Kazêh »
hello all, I was trying to save the permissions for one of my applications and this error came out.
http://postimg.org/image/9bjxu9gn1/
I found the following related error:
http://www-01.ibm.com/support/docview.w ... wg21611601
http://www-01.ibm.com/support/docview.w ... wg21454522
my pmpsvc.log:
	at java.lang.Thread.run(Thread.java:736)
2013-12-02 07:40:51,652 [http-9510-6] ERROR (setApplicationSecurity setApplicationSecurity setNodeSecurityInfo) com.ibm.cognos.pmpsvc.PMPService - com.ibm.cognos.pmpsvc.handler.PMPTM1Exception: TI_INTERNAL[NA | }tp_clean_security_after_deployment | ProcessAborted ]
2013-12-02 07:42:06,222 [http-9510-6] ERROR (setApplicationSecurity setApplicationSecurity setNodeSecurityInfo) com.cognos.pmta.api.modelmanagement.accessor.TM1ObjectAccessor - Process failed to run }tp_clean_security_after_deployment
com.ibm.cognos.tm1.TM1Exception: ProcessAborted
	at com.ibm.cognos.tm1.Process.executeEnd(Native Method)
	at com.cognos.pmta.api.modelmanagement.accessor.TM1ObjectAccessor.executeProcess(TM1ObjectAccessor.java:1065)
	at com.cognos.pmta.api.modelmanagement.links.system.TM1SystemLink.executeImpl(TM1SystemLink.java:270)
	at com.cognos.planning.application.common.link.BaseLink.execute(BaseLink.java:66)
	at com.ibm.cognos.pmpsvc.handler.util.PmtaProcessUtil.executeTiProcess(PmtaProcessUtil.java:130)
	at com.ibm.cognos.pmpsvc.handler.util.PmtaProcessUtil.executeTiProcess(PmtaProcessUtil.java:78)
	at com.ibm.cognos.pmpsvc.handler.ApplicationDeploymentHandler.createApplicationSecurity(ApplicationDeploymentHandler.java:501)
	at com.ibm.cognos.pmpsvc.handler.ApplicationDeploymentHandler.deployPlanningSecurity(ApplicationDeploymentHandler.java:127)
	at com.ibm.cognos.pmpsvc.PMPService.deployAppSecurity(PMPService.java:4402)
	at com.ibm.cognos.pmpsvc.PMPService.setApplicationSecurityInfo(PMPService.java:4318)
	at com.ibm.cognos.pmpsvc.PMPService.setApplicationSecurity(PMPService.java:4167)
	at com.ibm.cognos.pmpsvc.PMPService.setApplicationSecurityJSON(PMPService.java:4102)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:48)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
	at java.lang.reflect.Method.invoke(Method.java:600)
	at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
	at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
	at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
	at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
	at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
	at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
	at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
	at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
	at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
	at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
	at com.ibm.cognos.pmpsvc.XML2JSONServletFilter.chainAndConvertSoapToJson(XML2JSONServletFilter.java:65)
	at com.ibm.cognos.pmpsvc.XML2JSONServletFilter.doFilter(XML2JSONServletFilter.java:50)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
	at com.ibm.cognos.pmpsvc.GzipFilter.doFilter(GzipFilter.java:53)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
	at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:852)
	at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
	at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
2013-12-02 07:42:06,222 [http-9510-6] ERROR (setApplicationSecurity setApplicationSecurity setNodeSecurityInfo) com.ibm.cognos.pmpsvc.PMPService - com.ibm.cognos.pmpsvc.handler.PMPTM1Exception: TI_INTERNAL[NA | }tp_clean_security_after_deployment | ProcessAborted ]
my tm1server.log:
ERROR   2013-12-02 15:29:55.876   TM1.Process   Process "}tp_add_user_security_from_file": : Execution was aborted. Error file: <TM1ProcessError_20131202152955_}tp_add_user_security_from_file.log>
4772   [25]   ERROR   2013-12-02 15:29:55.954   TM1.Mdx.Interface   "37e41233-0e06-4243-bb57-3eac27bd6ece" : object not found (rte 81)
4772   [25]   INFO   2013-12-02 15:40:33.356   TM1.Process   Process "}tp_application_deploy" executed by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:33.356   TM1.Process   Process "}tp_util_does_dim_have_cube_name" run from process "}tp_application_deploy" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:33.356   TM1.Process   Process "}tp_util_does_dim_have_cube_name":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:40:33.356   TM1.Process   Process "}tp_reset_permission_on_failure" run from process "}tp_application_deploy" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:33.356   TM1.Process   Process "}tp_reset_permission_on_failure":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:40:33.356   TM1.Process   Process "}tp_get_application_attributes" run from process "}tp_application_deploy" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:33.356   TM1.Process   Process "}tp_get_application_attributes":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:40:33.356   TM1.Process   Process "}tp_application_deploy":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:40:33.449   TM1.Process   Process "}tp_modify_application_attribute" executed by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:33.449   TM1.Process   Process "}tp_modify_application_attribute":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:40:50.715   TM1.Server   TM1CubeImpl::ProcessFeeders: Computing feeders for base cube '}tp_application_permission}{456e901c-f6f6-42e2-8303-a0a34f6a2b52}'.
4772   [25]   INFO   2013-12-02 15:40:50.715   TM1.Server   TM1CubeImpl::ProcessFeeders: Done computing feeders for base cube '}tp_application_permission}{456e901c-f6f6-42e2-8303-a0a34f6a2b52}'.
4772   [25]   INFO   2013-12-02 15:40:50.746   TM1.Process   Process "}tp_modify_application_attribute" executed by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:50.746   TM1.Process   Process "}tp_modify_application_attribute":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:40:50.871   TM1.Process   Process "}tp_util_export_hierarchy" executed by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:50.871   TM1.Process   Process "}tp_get_top_node" run from process "}tp_util_export_hierarchy" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:50.871   TM1.Process   Process "}tp_get_parent_in_subset" run from process "}tp_get_top_node" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:50.871   TM1.Process   Process "}tp_get_parent_in_subset":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:40:50.871   TM1.Process   Process "}tp_get_top_node":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:40:50.887   TM1.Process   Process "}tp_util_export_hierarchy":  finished executing normally, elapsed time 0.02 seconds
4772   [25]   INFO   2013-12-02 15:40:50.996   TM1.Process   Process "}tp_incr_deploy_application_security" executed by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:50.996   TM1.Process   Process "}tp_get_log_file_names" run from process "}tp_incr_deploy_application_security" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:50.996   TM1.Process   Process "}tp_get_log_file_names":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:40:50.996   TM1.Process   Process "}tp_incr_create_update_artifacts" run from process "}tp_incr_deploy_application_security" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:51.277   TM1.Process   Process "}tp_incr_create_update_artifacts":  finished executing normally, elapsed time 0.28 seconds
4772   [25]   INFO   2013-12-02 15:40:51.293   TM1.Process   Process "}tp_util_convert_dynamic_subset_to_static" run from process "}tp_incr_deploy_application_security" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:51.293   TM1.Process   Process "}tp_util_convert_dynamic_subset_to_static":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:40:51.309   TM1.Process   Process "}tp_util_convert_dynamic_subset_to_static":  finished executing normally, elapsed time 0.02 seconds
4772   [25]   INFO   2013-12-02 15:40:51.309   TM1.Process   Process "}tp_incr_update_permission_cell_security" run from process "}tp_incr_deploy_application_security" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:51.309   TM1.Process   Process "}tp_get_log_file_names" run from process "}tp_incr_update_permission_cell_security" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:51.309   TM1.Process   Process "}tp_get_log_file_names":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:40:51.309   TM1.Process   Process "}tp_incr_update_single_node_and_group" run from process "}tp_incr_update_permission_cell_security" by user "Pablo"
4772   [25]   ERROR   2013-12-02 15:40:51.324   TM1.Process   Process "}tp_incr_update_single_node_and_group": : Execution was aborted. Error file: <TM1ProcessError_20131202154051_}tp_incr_update_single_node_and_group.log>
4772   [25]   INFO   2013-12-02 15:40:51.324   TM1.Process   Process "}tp_incr_update_single_node_and_group" run from process "}tp_incr_update_permission_cell_security" by user "Pablo"
4772   [25]   ERROR   2013-12-02 15:40:51.340   TM1.Process   Process "}tp_incr_update_single_node_and_group": : Execution was aborted. Error file: <TM1ProcessError_20131202154051_}tp_incr_update_single_node_and_group.log>
4772   [25]   INFO   2013-12-02 15:40:51.340   TM1.Process   Process "}tp_incr_update_single_node_and_group" run from process "}tp_incr_update_permission_cell_security" by user "Pablo"
4772   [25]   ERROR   2013-12-02 15:40:51.355   TM1.Process   Process "}tp_incr_update_single_node_and_group": : Execution was aborted. Error file: <TM1ProcessError_20131202154051_}tp_incr_update_single_node_and_group.log>
4772   [25]   INFO   2013-12-02 15:40:51.355   TM1.Process   Process "}tp_incr_update_single_node_and_group" run from process "}tp_incr_update_permission_cell_security" by user "Pablo"
4772   [25]   ERROR   2013-12-02 15:40:51.371   TM1.Process   Process "}tp_incr_update_single_node_and_group": : Execution was aborted. Error file: <TM1ProcessError_20131202154051_}tp_incr_update_single_node_and_group.log>
4772   [25]   INFO   2013-12-02 15:40:51.371   TM1.Process   Process "}tp_incr_update_single_node_and_group" run from process "}tp_incr_update_permission_cell_security" by user "Pablo"
4772   [25]   ERROR   2013-12-02 15:40:51.387   TM1.Process   Process "}tp_incr_update_single_node_and_group": : Execution was aborted. Error file: <TM1ProcessError_20131202154051_}tp_incr_update_single_node_and_group.log>
4772   [25]   INFO   2013-12-02 15:40:51.387   TM1.Process   Process "}tp_incr_update_single_node_and_group" run from process "}tp_incr_update_permission_cell_security" by user "Pablo"
4772   [25]   ERROR   2013-12-02 15:40:51.402   TM1.Process   Process "}tp_incr_update_single_node_and_group": : Execution was aborted. Error file: <TM1ProcessError_20131202154051_}tp_incr_update_single_node_and_group.log>
4772   [25]   INFO   2013-12-02 15:40:51.402   TM1.Process   Process "}tp_incr_update_single_node_and_group" run from process "}tp_incr_update_permission_cell_security" by user "Pablo"
4772   [25]   ERROR   2013-12-02 15:40:51.418   TM1.Process   Process "}tp_incr_update_single_node_and_group": : Execution was aborted. Error file: <TM1ProcessError_20131202154051_}tp_incr_update_single_node_and_group.log>
4772   [25]   INFO   2013-12-02 15:40:51.418   TM1.Process   Process "}tp_incr_update_single_node_and_group" run from process "}tp_incr_update_permission_cell_security" by user "Pablo"
4772   [25]   ERROR   2013-12-02 15:40:51.434   TM1.Process   Process "}tp_incr_update_single_node_and_group": : Execution was aborted. Error file: <TM1ProcessError_20131202154051_}tp_incr_update_single_node_and_group.log>
4772   [25]   INFO   2013-12-02 15:40:51.434   TM1.Process   Process "}tp_incr_update_single_node_and_group" run from process "}tp_incr_update_permission_cell_security" by user "Pablo"
4772   [25]   ERROR   2013-12-02 15:40:51.449   TM1.Process   Process "}tp_incr_update_single_node_and_group": : Execution was aborted. Error file: <TM1ProcessError_20131202154051_}tp_incr_update_single_node_and_group.log>
4772   [25]   INFO   2013-12-02 15:40:51.449   TM1.Process   Process "}tp_incr_update_single_node_and_group" run from process "}tp_incr_update_permission_cell_security" by user "Pablo"
4772   [25]   ERROR   2013-12-02 15:40:51.465   TM1.Process   Process "}tp_incr_update_single_node_and_group": : Execution was aborted. Error file: <TM1ProcessError_20131202154051_}tp_incr_update_single_node_and_group.log>
4772   [25]   ERROR   2013-12-02 15:40:51.465   TM1.Process   Process "}tp_incr_update_permission_cell_security":  finished executing with errors. Error file: <TM1ProcessError_20131202154051_}tp_incr_update_permission_cell_security.log>
4772   [25]   ERROR   2013-12-02 15:40:51.465   TM1.Process   Process "}tp_incr_deploy_application_security":  finished executing with errors. Error file: <TM1ProcessError_20131202154051_}tp_incr_deploy_application_security.log>
4772   [25]   INFO   2013-12-02 15:40:51.543   TM1.Process   Process "}tp_clean_security_after_deployment" executed by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:51.543   TM1.Process   Process "}tp_get_application_attributes" run from process "}tp_clean_security_after_deployment" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:40:51.559   TM1.Process   Process "}tp_get_application_attributes":  finished executing normally, elapsed time 0.02 seconds
4772   [25]   ERROR   2013-12-02 15:40:51.559   TM1.Process   Process "}tp_clean_security_after_deployment": : Execution was aborted. Error file: <TM1ProcessError_20131202154051_}tp_clean_security_after_deployment.log>
4772   [25]   ERROR   2013-12-02 15:40:51.652   TM1.Mdx.Interface   "a28763d4-f3a2-4bf2-8fa4-4107afd3601e" : object not found (rte 81)
4772   [25]   INFO   2013-12-02 15:42:00.425   TM1.Process   Process "}tp_application_deploy" executed by user "Pablo"
4772   [25]   INFO   2013-12-02 15:42:00.425   TM1.Process   Process "}tp_util_does_dim_have_cube_name" run from process "}tp_application_deploy" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:42:00.425   TM1.Process   Process "}tp_util_does_dim_have_cube_name":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:42:00.425   TM1.Process   Process "}tp_reset_permission_on_failure" run from process "}tp_application_deploy" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:42:00.425   TM1.Process   Process "}tp_reset_permission_on_failure":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:42:00.425   TM1.Process   Process "}tp_get_application_attributes" run from process "}tp_application_deploy" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:42:00.441   TM1.Process   Process "}tp_get_application_attributes":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:42:00.441   TM1.Process   Process "}tp_application_deploy":  finished executing normally, elapsed time 0.02 seconds
4772   [25]   INFO   2013-12-02 15:42:00.534   TM1.Process   Process "}tp_modify_application_attribute" executed by user "Pablo"
4772   [25]   INFO   2013-12-02 15:42:00.534   TM1.Process   Process "}tp_modify_application_attribute":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:42:05.628   TM1.Server   TM1CubeImpl::ProcessFeeders: Computing feeders for base cube '}tp_application_permission}{456e901c-f6f6-42e2-8303-a0a34f6a2b52}'.
4772   [25]   INFO   2013-12-02 15:42:05.628   TM1.Server   TM1CubeImpl::ProcessFeeders: Done computing feeders for base cube '}tp_application_permission}{456e901c-f6f6-42e2-8303-a0a34f6a2b52}'.
4772   [25]   INFO   2013-12-02 15:42:05.659   TM1.Process   Process "}tp_modify_application_attribute" executed by user "Pablo"
4772   [25]   INFO   2013-12-02 15:42:05.659   TM1.Process   Process "}tp_modify_application_attribute":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:42:05.784   TM1.Process   Process "}tp_util_export_hierarchy" executed by user "Pablo"
4772   [25]   INFO   2013-12-02 15:42:05.784   TM1.Process   Process "}tp_get_top_node" run from process "}tp_util_export_hierarchy" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:42:05.784   TM1.Process   Process "}tp_get_parent_in_subset" run from process "}tp_get_top_node" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:42:05.784   TM1.Process   Process "}tp_get_parent_in_subset":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:42:05.784   TM1.Process   Process "}tp_get_top_node":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:42:05.800   TM1.Process   Process "}tp_util_export_hierarchy":  finished executing normally, elapsed time 0.02 seconds
4772   [25]   INFO   2013-12-02 15:42:05.909   TM1.Process   Process "}tp_incr_deploy_application_security" executed by user "Pablo"
4772   [25]   INFO   2013-12-02 15:42:05.909   TM1.Process   Process "}tp_get_log_file_names" run from process "}tp_incr_deploy_application_security" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:42:05.909   TM1.Process   Process "}tp_get_log_file_names":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:42:06.019   TM1.Process   Process "}tp_incr_update_permission_cell_security" run from process "}tp_incr_deploy_application_security" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:42:06.019   TM1.Process   Process "}tp_get_log_file_names" run from process "}tp_incr_update_permission_cell_security" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:42:06.034   TM1.Process   Process "}tp_get_log_file_names":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   INFO   2013-12-02 15:42:06.034   TM1.Process   Process "}tp_incr_update_permission_cell_security":  finished executing normally, elapsed time 0.01 seconds
4772   [25]   INFO   2013-12-02 15:42:06.034   TM1.Process   Process "}tp_incr_deploy_application_security":  finished executing normally, elapsed time 0.13 seconds
4772   [25]   INFO   2013-12-02 15:42:06.112   TM1.Process   Process "}tp_clean_security_after_deployment" executed by user "Pablo"
4772   [25]   INFO   2013-12-02 15:42:06.112   TM1.Process   Process "}tp_get_application_attributes" run from process "}tp_clean_security_after_deployment" by user "Pablo"
4772   [25]   INFO   2013-12-02 15:42:06.112   TM1.Process   Process "}tp_get_application_attributes":  finished executing normally, elapsed time 0.00 seconds
4772   [25]   ERROR   2013-12-02 15:42:06.128   TM1.Process   Process "}tp_clean_security_after_deployment": : Execution was aborted. Error file: <TM1ProcessError_20131202154206_}tp_clean_security_after_deployment.log>
4772   [25]   ERROR   2013-12-02 15:42:06.222   TM1.Mdx.Interface   "83a8b0fc-8a5c-425e-a47d-e40347b8ec89" : object not found (rte 81)
i was creating new users and new groups in the performance modeler and every time i add a new one i got an error, but then i refreshed the performance and the group was there. i think the all " }tp_incr_update_single_node_and_group" run from process "}tp_incr_update_permission_cell_security" are for that.
I reset the aplication but i didnt work, so i tryed the other relate post that it says to change the permissions of the TI process
and they have the read process in the everyone group:
http://postimg.org/image/vtn6207zx/
I had rules that were in security cubes related to the names of the groups in the performance, i already corrected that rules, so no errors in rules in security cubes. i will check it out one more time tho.
in short, i was creating new users and groups, i had security cubes associated with the group names and rules , every time I tried to add a group I got some weird error, and refreshing the model group appeared. then i try to add the rights in contributor and my application got this unexpected error.
Im trying to recreate the error in the performance, so i will post it later.
( the aplication was working fine )
any kind of help is welcome
Thanks.
paulsimon
Version: PA 2.0.5
Re: An unexpected error was generated by a ti process
Post by paulsimon »
Not sure if this is relevant but there is a limit to the number of groups that you can create in one session. You can override it in the TM1S.CFG. I think the default is around 20. Is it happening even for the first group?
Kazêh
Post by Kazêh »
hi paul, and yes, i change the GroupsCreationLimit to 120, i have a lot of groups so that's the firts thing i did.
and No, when i createn the firts 20 groups no error appeared.
I somehow got it working now, i can save the rights in the applications, what i did was desactivate the application, click on the rights, delete all the rights, save, reestart all the services, go to the rights again and tada!, i can save them now.
i went to the performance modeler and no errors when creating groups, im still worried tho.
some kind of bug , i dont really know. thanks anyways for reply to my post.
Kazeh.
