feeders for Elpar in the rule
macsir
Version: PAL 2.0.9
Post by macsir »
Hi, all
The following is the rule for a Enrol Ratio cube. It is getting base ratio from a Ratio cube by doing it at upper level of program. I am wondering if the feeder is right or not and over-feeding?
SKIPCHECK;
['Enrol Ratio'] = DB('Ratio',!Scenario,!Location,ELPAR('Program',!Program,1),!Course,'Base Ratio');
FEEDERS;
['Base Ratio'] => DB('Ratio',!Scenario,!Location,'All Programs',!Course,'Enrol Ratio');
EvgenyT
Version: PAL 2.0.8
Re: feeders for Elpar in the rule
Post by EvgenyT »
macsir wrote:Hi, all
SKIPCHECK;
FEEDERS;
You are very likely to overfeed if you are feeding a consolidation, remember all the children underneath will be feed .
macsir
Version: PAL 2.0.9
Post by macsir »
SKIPCHECK;
FEEDERS;
Yes, I know but how to improve it? Any idea? :geek:
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
Im not sure if this approach would suit your model, but you could create Feeder Consolidations in Program dimension to get more precise feeding
macsir
Version: PAL 2.0.9
Post by macsir »
EvgenyT wrote:Im not sure if this approach would suit your model, but you could create Feeder Consolidations in Program dimension to get more precise feeding
Thanks but what do you mean by Feeder Consolidations? Could you give me a general example?
Why do you feed this calculation? You have a rule at C level, which overrides the default aggregation algorithm in TM1.
EvgenyT
Version: PAL 2.0.8
Post by EvgenyT »
Wim Gielis wrote:Why do you feed this calculation? You have a rule at C level, which overrides the default aggregation algorithm in TM1.
You are right Wim, sorry I overlooked the calculation statement.
macsir
Version: PAL 2.0.9
Post by macsir »
If no feeders, all the C level program of Enrol Ratio will be unfed?
macsir
Version: PAL 2.0.9
Post by macsir »
Sorry for the confusion, I think the complete code is the following and the value in Assumption cube is not zero.
SKIPCHECK;
['Enrol Ratio'] = DB('Ratio',!Scenario,!Location,ELPAR('Program',!Program,1),!Course,'Base Ratio') * DB('Assumption','Medium Program Weight','value');
FEEDERS;
macsir
Version: PAL 2.0.9
Post by macsir »
Ok, I think I have got it. The following code should be fine. The reason I am using the root element 'All Programs' is that in the rule, there are other ELPAR , such as ELPAR('Program',ELPAR('Program',!Program,1),1) etc. which across all the level of this program dimension. That's why I am using the root consolidation to feed all the programs.
But in order to get better performance, I would like to try attribute rather than ELPAR in the rule.
SKIPCHECK;
FEEDERS;
['Base Ratio'] => DB('Ratio',!Scenario,!Location,ELPAR('Program',!Program,1),!Course,'Enrol Ratio');
Is this rule writting the Ratio cube, or a different one?
If different, what is the dimensionality?
Duncan P
Version: 9.5.2 10.1 10.2
Excel Version: 2003 2007
Post by Duncan P »
Since someone has mentioned feeding C level calculations I think I will just pop this reference in as a reminder of the complications
Supress Zero and FEEDERs.
macsir
Version: PAL 2.0.9
Post by macsir »
Wim Gielis wrote:Is this rule writting the Ratio cube, or a different one?
It is the ratio cube.
macsir
Version: PAL 2.0.9
Post by macsir »
Duncan P wrote:Since someone has mentioned feeding C level calculations I think I will just pop this reference in as a reminder of the complications
Thanks, duncan. I have checked that.
macsir
Version: PAL 2.0.9
Post by macsir »
macsir wrote:Ok, I think I have got it. The following code should be fine. The reason I am using the root element 'All Programs' is that in the rule, there are other ELPAR , such as ELPAR('Program',ELPAR('Program',!Program,1),1) etc. which across all the level of this program dimension. That's why I am using the root consolidation to feed all the programs.
SKIPCHECK;
FEEDERS;
I have finished testing with attributes. And it does take less memory and better performance than ELPAR in the rule. Next time, if that is the case, I will use attributes directly. :D
