tm1 10.2 IF1 cognos insight
flesh2011
OLAP Product: tm1
Version: 10.1.1
Post by flesh2011 »
HI.
We`ve installed the IF1.
cognos security
1. when starting a node form a PM created application (approval) we get this in a loop.
have tried to force downgrade version on both CI and PM but still the same.
Application web client works.
2. when having 2 or more applications on the same tm1 server and trying to change ownership behaviour in 1 app the others also change.
3. Element rights on C: levels that an manually set to Read is still open and editable (numeric and no rule on c: ).
This worked in 10.1.1
A "fix" could be to wrire rule that C: level = N: level but that`s not a good solution.
element rights.JPG (30.81 KiB) Viewed 2143 times
4. When starting with a fresh install and add servers to tm1 applications with one admin user. add applications with the same user. all is a ok.
but when adding another admin user and remove admin rights to the 1 original adminuser, in tm1 application the new adminuser is treated as a regular user, with no editing rights.
5. when using cube view in TI as source the view mapping is not sticking with the subsets, and turns to "all". both static and dynamic subsets if there are more than 1 member.
thanks
