VBA N_Connect
AmbPin
Version: 9.5.2
Excel Version: 2007-10
VBA N_Connect
Post by AmbPin »
Regarding the simple code extract below:-
  Dim s As String
  s = Application.Run("N_CONNECT", sTM1Server, "UID", "PWD")
  If s = "" Then
    Debug.Print Application.Run("DimSiz", "TM1Server" & ":}Clients")
    Debug.Print Application.Run("DIMNM", "MyServer:}Clients", 1, "Alias")
    Debug.Print Application.Run("N_DISCONNECT")
  End If
This works fine the first time I run it, however the DimNM function returns blank on every subsequent run. Is this to be expected?
AmbPin
Version: 9.5.2
Re: VBA N_Connect
Post by AmbPin »
Just added a call to TM1Refresh as shown below:-
  Dim s As String
  If s = "" Then
    Application.Run "TM1Refresh"
  End If
Which now makes it work OK. Is the the best way to do this?
