TM1 rules feeders problem
dilip
Version: 9.4
Post by dilip »
I have made the hierarchy in my dimension as under A there are child B & C and under B there are child e & f and under C there are g & h.In the rule part I have seen every thisng is correct but value is getting feeded in A but not in B and C.similarly the value is also getting fed for e&f ad g & h,but only Iam not able to see the values for B and C consolidated on A Iam getting a correct consolidated value.I have check the feeders properly,Traced calculation also and also when iam doing a right click on B and C and select option as check feeders nothing Iam seeing that means that value is ccorrectly feeding.I don't know why value is not getting summing up at B and C automatically as in hierchy B is the sum of e & f. and C is the sum of g & h. why value is not getting consolidated at B and C.
Any guess anyone.....I have almost spend 2 days on this but no guess.
Re: TM1 rules feeders problem
dilip wrote:also when iam doing a right click on B and C and select option as check feeders nothing Iam seeing that means that value is ccorrectly feeding
No, it doesn't. Checking feeders on a consolidated node is not a valid function. You can only check feeders on leaf level nodes. In your case that would be e,f,g, and h. As to why it's not getting fed I have no clue. You can spend two days on this but can't take the 15 or so minutes it would take to read the request for assistance guidelines????? How can anyone help you without your code?
