Automatically Rebuild Active Form Websheets
cdhodge2002
Post by cdhodge2002 »
I have a question does anybody know how to automatically update an active form tm1rptrow whenever a title row item is changed?
I currently have my web.config file set up like this per the IBM site I saw online
<!-- Websheet Paging Settings -->
<add key="WebsheetPaging" value="Enabled=true;PageSize=100;PageResetMode=3" />
I have the tm1rptrow using a MDX statement so whenever I update an item in the title area the list will change, however this requires an active form rebuild. My client would like not to rebuild the form everytime they make a change. Again this is over the web.
cdhodge2002
Re: Automatically Rebuild Active Form Websheets
So I am guessing this is not possible?
There are some tricks. Try replacing SUBNM title references with DBR strings with picklists. This can force rebuild of the active form as this is the default behavior when a picklist value is changed.
Depending on where you are I think there are some topics on this in the agenda of the Cubewise TM1 conferences later this month.
