I am currently running Cognos TM1 10, I have three tm1 server instances on the same server, 1 with BI security and 2 without.
When I go to contributor it automatically logs me into the server with BI security. There are users here that only will log into the server without BI security using i.e. admin.
From memory I used to be able to select between the 3 servers at the contributor log in screen?
FYI. The Tomcat app file fpmsvc_config.xml has the BI security server listed first under the <servers>.
Any help is greatly appreciated.
SW.
Cant Select tm1 server instance in Contributor login
- OLAP Product: Cognos
- Version: 10.2.1
- Version: All
- Excel Version: All
Re: Cant Select tm1 server instance in Contributor login
When you say you 'used' to be able too, what has changed?
Are the servers visible in Cognos Administration/ IBM Cognos Configuration?
- Version: 10.2
With Contributor you can only use 1 securitymode. So if you had choosen the BI Security, you can't see the TM1 Native Security servers or vica versa.
- Version: 10.2.1
Thanks all!
There was an issue with my tm1s.cfg file.. everything now works as expected!
