Is it possible in TM-1 do such things
1. apply some style - bold or for example Italic for some elements in subset or dimension (some sort of format)
2. do the same thing for date - some lines are bold - where I want and others - are as usual
for example
Region1 1 2 3
Region2 1 2 3
Region3 1 2 3
May be possible not in Architect but in some clients - Application Web or Insight
Formatting settings in TM1
EP_explorer
- OLAP Product: PAL
- Version: 2.0.9
- Harvey
- Version: TM1 8.3 onwards
- Excel Version: 2003 onwards
Re: Formatting settings in TM1
If you create an Excel worksheet, you can use any kind of formatting that Excel supports, including conditional formatting. I would imagine there would be a way to do what you want in Excel -- there's very little you can't get done with a little imagination!
Many of Excel's formatting features work in Websheets, but you may have to play around a bit to get it to work.
Insight may one day do what you want, but the current version does not as far as I know.
- Olivier
- Version: Tm1 10.2.2fp4 -> 2.09
- Excel Version: Excel 2013 - 2019
I don't think this can be done in TM1 Cube views if that s what the OP had in mind.
In Excel, it could be done in so many ways as Lazarus said.
I would just add that If the element to format is determined by data / conditions / position in hierarchy / rules calculations,
you could consider to create a specific attribute to generate a reference you could use to support your conditional formatting in Excel.
Hope this helps,
Kind Regards,
Olivier
Hope this helps,
Kind Regards,
Olivier
HTH
Olivier
Olivier
EP_explorer
- OLAP Product: PAL
- Version: 2.0.9
Thank you for answers.
I wanted to format elements based on elements attributes indeed but in web clients not in Excel
It is pity if it is impossible
- stephen waters
- Version: 10_2_2
- Excel Version: Excel 2010
It is possible with websheets? They are web clients but using Excel formatting. Much better than Web views. Very quick and simple though they may need a bit of fine tuning between Excel and Websheet versions.EP_explorer wrote:I wanted to format elements based on elements attributes indeed but in web clients not in Excel
