Natural Consolidation to calculate %
conray
- Version: 9.5.2
- Excel Version: Excel 2010
Is it possible to use natural consolidation to calculate %, such as:
A amount / B amount = AB%
AB%
|_ A amount
|_ B amount
AB%
|_ A amount
|_ B amount
Server OS: Windows Server 2008 R2 (64-bit)
TM1: v9.5.2 FP1
MS Office: Microsoft Excel 2003, 2010
TM1: v9.5.2 FP1
Re: Natural Consolidation to calculate %
Not in a consolidation; for that you use Rules.conray wrote:Is it possible to use natural consolidation to calculate %, such as:
AB%
|_ A amount
|_ B amount
Exception: If the percentage is a fixed amount (say 10%) rather than being stored in another element, you can use a weighting when you add A Amount to the consolidation AB%. If the amount is variable, though, Rules are required.
Christopher Kernahan
- Version: 10.1
- Excel Version: Office 2010
Hi conray,
You'll have to use Rule Calculations for that.
conray
- Version: 9.5.2
ok understood, thanks for the feedback.
TM1: v9.5.2 FP1
TM1: v9.5.2 FP1
This trick can be used to have numeric values expressed in thousands (or millions):Alan Kirk wrote:Exception: If the percentage is a fixed amount (say 10%) rather than being stored in another element, you can use a weighting when you add A Amount to the consolidation AB%. If the amount is variable, though, Rules are required.
make a consolidation out of the original value, with weight 0.001 (or 0,000001).
Apply numberformatting and you're done. It saves us from writing a lot of feeders and
therefore, the TM1 model is potentially a lot smaller and efficient.
If you have a separate "scale" dimension in the model using exactly this technique that you add to all cubes as required then this is an even better trick.Wim Gielis wrote:This trick can be used to have numeric values expressed in thousands (or millions):
conray
- Version: 9.5.2
i am lost
TM1: v9.5.2 FP1
TM1: v9.5.2 FP1
You're on Earth, third planet of a yellow star commonly referred to as The Sun which is located in one of the more unfashionable backwaters of the Alpha quadrant of the Milky Way galaxy.conray wrote:i am lost
Or if that doesn't answer your question...
Are you referring to weightings in consolidations?
If so, what we're talking about is this. Suppose that you have 5 N level elements in a consolidation, named A to E. By default these have a weighting of 1, meaning that the consolidation's value will be A + B + C + D + E, agreed?
However the weighting doesn't have to be 1; it can be any value. So suppose that you set the weighting for each of them to 0.001. The consolidation's value will then be (0.001 * A) + (0.001 * B) + (0.001 * C) + (0.001 * D) + (0.001 * E).
So supposing that A, B, C, D and E were in millions, your consolidation is now reporting the value rounded to thousands, without having to write a rule to do it or relying on rules functions which are less efficient than consolidations.
Duncan P
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
Looking at OP's original question I would be lost too if I were OP. He (?) asked about division and we got a (nonetheless interesting) discussion of scaling.
Basically natural consolidation adds. OP wants to divide. The only way for OP to do this with natural consolidations is to add the logarithms of the numbers (with a weight of -1 on the second) and then antilog. This would require a rule to do the log and antilog and is also much complicated by edge conditions (log(0) is -infinity) so why not just divide anyway.
You must have been thinking of another piece of software - or are you a closet Performance Modeler userlotsaram wrote:that you add to all cubes as required
What does a weighting of 0.001 do?Duncan P wrote:Looking at OP's original question I would be lost too if I were OP. He (?) asked about division and we got a (nonetheless interesting) discussion of scaling.
Or, since we're talking percentages (or were in the original post), what does a weighting of 0.01 do?
Hence my original "Exception" qualification
I wrote:Exception: If the percentage is a fixed amount (say 10%) rather than being stored in another element, you can use a weighting
conray
- Version: 9.5.2
okay, so this is what i understood:
1. Alan is trying to explain, that we can round values using weightings instead of applying rounding method directly in rules.
2. There is no direct way to use natural consolidation to do a division.
TM1: v9.5.2 FP1
TM1: v9.5.2 FP1
